Metalstrix wrote:Whats the status on your car man?
Its at the shop, so hopefully it should be running soon.
Will update everyone asap!
BST50N wrote:So fwd Evo X powered lancer? Would be lighter than the evo probably should be quick if you can get the power down! Just throw some 265s on the front lol
scott_drake wrote:Make sure the fwd gearbox has the same mounting points as the 4b11t block And i would highly suggest so you dont blow your gearbox to this this list Custom light weight flywheel Custom exedy hd clutch kit Arp Flywheel bolts Arp Pressure Plate Bolts Map Performance, Clutch Master Cylinder for evo 10 Custom Braided Clutch Line (map line MAY not work) Quaife LSD Gearbox Rebuild to fit lsd and strengthen 1st and 2nd gear Custom Gearbox Mounts Custom Engine Mounts And while your at it, TWM cable bushes And make sure u upgrade your brakes!
scott_drake wrote:[quote:f8ae50a5d1=LiX]The highest powered FWD Lancer which I know broke a drive shaft at 500 Nm, but his transmission is still holding good and this is not low mileage car.[/quote:f8ae50a5d1] if it is a CJ than i retract my previous statement
