Window Tints
Dummer
Postby Dummer » Mon Mar 23, 2009 10:49 pm
well you can say whatever you like but my tints were done by the same guy the local dealers use and he felted the seals and they have already scratched up the driver's side window. but they did take a few months to appear. also keep in mind I open my window up and down at least twice every weekday to swipe my proxy card at work.
If you dont believe me I'll try take photos, but my seals are felted and they still have scratched the tint.
Even the window tinter said the seals on new mitsubishis are sh!t, I trust the window tinter to know a thing or two about the quality of window seals. ;)
Panther4B11
Postby Panther4B11 » Mon Mar 23, 2009 10:53 pm
Yeah Mitsu did my windows too. No seals tho and my tints are stuffed.
Ozie
Postby Ozie » Mon Mar 23, 2009 11:00 pm
i have a VRX & it comes with the Privacy Glass on the back window and rear door windows & my front door windows were Tinted by the dealer,
and they havn't got a single scratch on them..... touch wood....
and i have 3 kids lol.....
i know the privacy glass is built in but its pretty good going for whoever the dealer got to do my front door Tints.......lol..
bigdave_1988
Postby bigdave_1988 » Mon Mar 23, 2009 11:09 pm
go ahead fix monster open a poll
for mitsu dealer tint
against mitsu dealer tint
but only the people who have had it done by the dealer can vote.... sound fair
777_AJB
Postby 777_AJB » Thu Mar 26, 2009 7:04 pm
i got privacy glass on back windows and got dealer to get the front tinted and there fine
Mizta B
Postby Mizta B » Thu Mar 26, 2009 7:20 pm
My VRX is 5 months old and so far no scratches on the front dealer tinted windows (touch wood)
No complaints so far
Merlinised....
Speedie
Postby Speedie » Thu Mar 26, 2009 7:59 pm
Dealer tinted on the RA no scratches.
Rina2009
Postby Rina2009 » Thu Mar 26, 2009 8:15 pm
I read on the net the VRX and above come with privacy glass.. so there no issue there... only VR and ES models... have the problem...
Bandit
Postby Bandit » Thu Mar 26, 2009 8:21 pm
Mitsubishi dealers (or dealers in general) don't tint windows. They take the car to a window tinting place nearby and get it done.
I have investigated the scratching problem with my local SolarTint (who does the Mitsubishi dealer's tinting in my area) and he showed me the problem and how they fix it for lancers and outlanders. They cut out about 2mm of some hard rubber sleeve down into the window that causes the scratches. They havent had any problems since they've been doing this, either with scratches or any window leaks. I will be getting mine done by them ASAP (incl. clear UV film on the privacy glass at the rear).
ClubCJ's first Sportback
Rina2009
Postby Rina2009 » Thu Mar 26, 2009 8:33 pm
i herd other wise....from my tinter...... it not fixing the problem....
and i think a window seal is important... going about cutting things out isnt an answer....
its not good enough on mits behalf....
i
Bandit
Postby Bandit » Thu Mar 26, 2009 8:37 pm
The part I am talking about is not a seal - it something else down in the door. Cutting it down by 2mm has worked so far. He knew exaclty what I was tlaking about when I went there a couple of weeks ago and actually showed me a piece they'd removed from a CJ. Outlander doors have the same problem.
Rina2009
Postby Rina2009 » Thu Mar 26, 2009 8:57 pm
this is what ive found on the net
http://www.tintprotector.com/mitsubishi/index.htm
i still dont think it will help....
asHxP
Postby asHxP » Thu Mar 26, 2009 8:59 pm
When you take the seal out there is two strips.. the one you can see when the seal is in and the lower one that you cant see (sorry its the best I could explain it). Basically I found the lower one to be the problem. I fixed it up good with felt tho and so far no problem. Too bad I realised that after it got scratched =/ lol.
I do think felt works.. just depends on how you put it on and where you buy it from. however I havent had mine in for a long enough time to tell whether the felt wears or not
777_AJB
Postby 777_AJB » Thu Mar 26, 2009 9:19 pm
big daves car is a vr
Mizta B
Postby Mizta B » Thu Mar 26, 2009 9:30 pm
Does the clear film on the privacy glass help much if applied?????
I haven't had this done to mine
Merlinised....
Users browsing this forum: No registered users and 130 guests
