theBIGbang - Tim - SA
RAwannabe
Postby RAwannabe » Thu Feb 24, 2011 9:31 am
mrwannabe wrote:Welcome Tim, so what's already been done to your ES?
sorry didn't check your Garage, what do you mean is not connected? the turbo and intercooler only for looks?
theBIGbang
Postby theBIGbang » Thu Feb 24, 2011 9:01 pm
I purchased it that way. I am going to be getting it connected though. It didn't make sense to me either, but that's what the previous owner obviously wanted for some straaaaange reason.
Postby sleeper » Fri Feb 25, 2011 7:53 am
u cant connect a turbo to an es, youll break the engine.
theBIGbang
Postby theBIGbang » Fri Feb 25, 2011 10:04 am
Can you define break the engine?
Chubb
Postby Chubb » Fri Feb 25, 2011 10:27 am
*boom* *pray2* :P
Postby ofey » Fri Feb 25, 2011 10:36 am
The engine blocks in an RA and an ES/VR/VRX are the same. However the connectors and pipework are NOT the same. Their operating tolerance is much lower. Directly bolting on and thinking your pipework and tubing will work is what I suspect Sleeper means by breaking your engine. Literally it will break.
If you're connecting it for looks and don't intend for the turbo to operate, well and good, I don't think you'll have a problem. Only thing is you're carrying about alot of unnecessary weight.
However, if you're looking to get it all working, you'll have alot more parts to replace and buy. Furthermore, the ECU will heave to be changed to accommodate for the turbo.
Postby sleeper » Fri Feb 25, 2011 11:40 am
no, i dont think even the blocks are the same ofey, (both the RA and the EVO have the 4b11T. apparently the water jackets are bigger in a 4b11T, the 4b11T is also lower compression, the bearings and con rods are stronger, the head is different, really NOT in any way the same engine.
pls correct me if i am wrong?
and yeah, chubb has it accurately depicted, i mean terminally damaged as in seized or blown up.
Postby sleeper » Fri Feb 25, 2011 11:45 am
theres a long list somewhere on here on what u need to do to bring a 4b11 engine up to near 4b11T spec.
AJjnr86
Postby AJjnr86 » Fri Feb 25, 2011 3:49 pm
Welcome to the club buddy
I think we need pics of the turbo, can c the intercooler in ur garage, but how is the turbo "fitted" without being connected, as the turbo is held in but the exhaust manifold...
OHH YEA!!!!
spareparts
Postby spareparts » Fri Feb 25, 2011 8:26 pm
the piston pin is also 5 tho advances to help it rev.... and yea lower comp piston, head castings are different, cams are different, intake mainafolt is different to, na's are plastic ra & evos are alloy.
the voices may not be real, but they have some pretty good ideas :D:D
theBIGbang
Postby theBIGbang » Sat Feb 26, 2011 2:47 pm
It's all good. I've had a chat to a friend of mine who used to be a sub-assembly technician for FPR, and he's said he'll find out what needs to be done to get the engine ready for it and he'll get it all set for me.
