CF gauge pods
tadz0rz
Postby tadz0rz » Sun Mar 07, 2010 8:38 am
Thanks Billy
JaCe
Postby JaCe » Sun Mar 07, 2010 8:55 am
tryg wrote:http://www.plxdevices.com/multigauges.html
Damn their stuff looks epic!
tryg
Postby tryg » Sun Mar 07, 2010 9:52 am
these are owned by just about every US-based EVO driver.. bound to be a non-issue...
PYLee
Postby PYLee » Sun Mar 07, 2010 11:30 am
the gauge pod or the gauge itself ?
Lancer Evolution 10MR
Aspired
Postby Aspired » Sun Mar 07, 2010 11:43 am
The other option is a steering column pod mount.
http://cgi.ebay.com.au/CF-steering-colu ... 3ca809622e
scraverX
Postby scraverX » Sun Mar 07, 2010 11:45 am
If gauges in the A pillar were a big enough issue with regard to defectability then custom A pillar speaker mounts would be as well.... surely?
Car & Home audio nut.
Blakey
Postby Blakey » Sun Mar 07, 2010 11:51 am
scraverX wrote:If gauges in the A pillar were a big enough issue with regard to defectability then custom A pillar speaker mounts would be as well.... surely?
what kind of speakers are you gonna put in your A pillar? its only really big enough to fit a tweet, and you can just recess it in the pillar so it would be no issue at all.
there is no need to have a midbass in your pillar so close to your head, unless they are directional speakers. but, you would be better off just buying better larger midbass to stick in your door.
scraverX
Postby scraverX » Sun Mar 07, 2010 12:52 pm
I'm not doing it... mine are going in the factory locations. Ninja install ;)
I have, however, seen SQ competition installs with a 3-way set of splits where the tweet and a small (2" or 3") mid are mounted in the A-pillar and a 6" mid-bass is mounted in the door.
Part of the judging criteria in SQ is positioning of the front Stage on an X, Y & Z axis. Optimum stage position comes down to speaker placement.
Completely off topic so that's probably enough...
tryg
Postby tryg » Sun Mar 07, 2010 3:44 pm
I have to get motivated to fit this.. show you all.. I ordered both in bulk, going to try to make these available to people.. will first seek permission.
Will try to find time to make a 'Check-it-out' video shortly...
Sickbunny
Postby Sickbunny » Sun Mar 07, 2010 3:47 pm
that pod looks great, which PLX gauge did you order?
Graham
Postby Graham » Sun Mar 07, 2010 4:17 pm
I like this!
this + this = win
Too bad I can't afford it :(
Daily Driver: Yamaha R1
scraverX
Postby scraverX » Sun Mar 07, 2010 5:02 pm
I do like the look of it a lot, I'll admit. Not sure if I'd get it or not, though.
Graham
Postby Graham » Sun Mar 07, 2010 5:24 pm
same, price is the bad factor for me :(
tryg
Postby tryg » Sun Mar 07, 2010 6:55 pm
I bought them much cheaper than the website price... I bought 5 x 52mm and 5 x 60mm PLX iMFD OBDii
tryg
Postby tryg » Sun Mar 07, 2010 7:00 pm
Graham wrote:I like this!
this + this = win
Graham, let you in on a hint... the factory that produces one, may also be the very same that made mine....
Return to “Image Gallery”
