Blanka's Body kit
tjoz
Postby tjoz » Thu Mar 04, 2010 5:27 pm
Be very careful when taking the plastic cover bits from the corners of the rear bar. Very fragile... Check your sideskirts too, dont put too much pressure on them up near the wheel arch areas.
Also have fun getting all the sticky tape off it :D Again be careful with the corner bits of the rear bar and your sideskirts. Did they give you the crappy plastic mesh too?
blanka
Postby blanka » Thu Mar 04, 2010 6:04 pm
ahahah thanks for the advise tjoz ahah yeh they did give me the mesh i havent taken a good look at it yet everything is still wrapped up
Uchiha Itachi
tjoz
Postby tjoz » Sat Mar 06, 2010 3:55 pm
Another one before I keep forgetting. Be very careful with the rear bar and the boot. I suggest you put either felt or a rubber strip along the bottom of the boot or shave/file down an indent large enough for the bottom of the boot to close without you having to close your eyes and cringe every time you shut your boot.
blanka
Postby blanka » Sat Mar 06, 2010 11:21 pm
ok did the test fitting today must i say i like the looks of it ^_^ front bar fits pretty good, rear bar could be better but its ok as well but its gonna need so work done b4 the kit is complet well here r some pics
the front beening striped
the front guards n hood
front bar
the rear
front bar n front guards fitted
sideview of the car
still need to fitt the rear door fittings but will need some tapes for it so we not doing that yet, next step is im gona go n get my exhaust changed cos the one i have on atm is backing onto a part of my rear bar, after that gona sand/prep and prime the kit then will paint it when everything is done.
Uchiha Itachi
PYLee
Postby PYLee » Sat Mar 06, 2010 11:32 pm
looks pretty good , you gonna need a new set of wheels , a wider and lower offset one :D
Lancer Evolution 10MR
blanka
Postby blanka » Sat Mar 06, 2010 11:45 pm
lpy2009 wrote:looks pretty good , you gonna need a new set of wheels , a wider and lower offset one :D
wheels looks so small now >.< but they will not be changed
Uchiha Itachi
Leez
Postby Leez » Sun Mar 07, 2010 12:01 am
It's looking MEAN! :D
Postby LZY_EYE » Sun Mar 07, 2010 6:38 am
How does it look on the fuel door side??
tjoz
Postby tjoz » Sun Mar 07, 2010 7:11 am
I think the wheels suit, I like that its not the Evo conversion kit its that other widebody one. I like the rear quarter panel area. Ideas :D
blanka
Postby blanka » Sun Mar 07, 2010 7:39 am
LZY_EYE wrote:How does it look on the fuel door side??
Uchiha Itachi
tadz0rz
Postby tadz0rz » Sun Mar 07, 2010 7:49 am
Mmmmmmmmmmm
that's the first body kit I saw when I got my lancer. Worth the wait it seems :D
SIR-VRX
Postby SIR-VRX » Sun Mar 07, 2010 11:58 am
Looks good, certainly unique :)
Postby bd-850 » Sun Mar 07, 2010 12:31 pm
car would look aswome painted in Flat Black :P
blanka
Postby blanka » Sun Mar 07, 2010 12:33 pm
yeh all the mates r saying i should paint it black but nah ima stick with blue
Uchiha Itachi
Postby bd-850 » Sun Mar 07, 2010 12:38 pm
no doubt, will look hot no matter how you do it
