Doing Front Bar
Graham wrote:Sidemount for the win
I've been pulled up twice since I've had it and the police haven't said anything about it, I did get a comment on my front lip though :p
It looks good! I want this mod but I really don't want to cut the front of my car up and don't want my car to look too much like a fakevo.
Maybe putting vinyl where you are meant to cut the bumper or mesh behind the holes on the addon might save cutting the bumper.
Looks great though, well done
i considered sidemount, but prefer perfect fit for my plates.. i dnt think theres any available..
yeh, you have to cut the bumper if you're goin for nose grille. the hole kinda goes in a little bit, and you need to cut the bumper to have it sitting flush..
car looks great btw!
- Exomondo
aspir3 wrote:Looks good in the pictures.
Is there any chance you can take more photos from the side/ close up?
Yeah I'm away for a couple days but I'll put some up when i get back.
Does this just stick over the centre of your bar, or do you have to cut the centre of your bar and fit this in? Sorry but I can not tell by the photos.
You have to cut the front bar to fit it through. If you have a look at the prep pics you can see the back of the cover and you could probably cut/sand those parts where the holes are so it would sit flush on the bar and then just have vinyl behind it.
thx for all the kudos btw
aspir3 wrote:Oh, I don't wont to cut the centre of my bar out.
Do you know what effect removing the centre of your bar has if your have an accident in the front of your car?
its not cutting the whole centre of your front bar.. (atleast for wat i did)
just cutting holes on the centre of ur front bar to make room for the holes of nose grille..
krz wrote:aspir3 wrote:Oh, I don't wont to cut the centre of my bar out.
Are there any pictures of the holes required to put in the bar to clear the mesh?
Or are there any inserts that can be fitted directly over our bars without putting holes in?
- Exomondo
You can see in this picture the raised bit(s), if you smoothed them flat then you would not need to cut holes in your front bar and it would sit flush.
A quick update though, the ends came away a bit so I grabbed some araldyte from the local bunnings and re-did them. I'd recommend pulling off all the 3M adhesive and use your own adhesive instead.
