LED SMD replacements for interior lights
bongo
Postby bongo » Fri Nov 13, 2009 9:48 pm
Thanks for the photos, looking good.
Postby The X » Fri Nov 13, 2009 9:55 pm
no probz. Better place to put them, rather than chop up before after shops in the Garage.
lancervr
Postby lancervr » Sat Feb 13, 2010 7:46 pm
hey just want 2 ask if a 16smd led replacement can fit in the boot light housing or do i have to leave it exposed?
~LancerVR~
Your friendly neighbourhood Red Devil (cj-red)
Deej
Postby Deej » Thu Apr 08, 2010 11:41 am
okies, looking at changing all my bulbs to LEDs now. With the map light, is there a certain directional type of LED that I can get as it seems to distract me when I am driving at night and someone switches on the map light to look for something. Basically, if the left hand side map light is switched on, I would like it to light up the left passengers seat and not have too much light come onto the drivers side.
funnyfi
Postby funnyfi » Thu Apr 08, 2010 12:00 pm
this is a bit noob but how do you take off the map light's covers to change the lights? I can get the cabin one open.. thanks
Postby ofey » Thu Apr 08, 2010 12:17 pm
You can actually pry the whole assembly out. Just stick a thin butter knife between the plastic and your roof liner. The whole map light assembly can be pryed out since it's only held by some stiff metal clips.
hansmitchel
Postby hansmitchel » Thu Apr 08, 2010 2:52 pm
or use a flat head screw driver (smallest one you have) and remove the clear cover - I took off the whole assembly out and it was a pain in the neck putting the LEDS in :( and then I removed the clear cover
milobob
Postby milobob » Mon Apr 12, 2010 4:34 pm
I wonder if an SMD light would help the sportback's boot... seeing how the light is not in the centre on one side..
hansmitchel
Postby hansmitchel » Mon Apr 12, 2010 8:10 pm
Hoges wrote:Hans- which direction should pry the clear plastic off from? is it much easier this way?
errrr, look at this picture, should be self explanatory. Do it for each corner where the clear cover is attached but be careful not to break it ;-)
It is much easier :)
Ral1rt
Postby Ral1rt » Mon Apr 12, 2010 9:04 pm
milobob wrote:I wonder if an SMD light would help the sportback's boot... seeing how the light is not in the centre on one side..
Yeah it sure will mate. I put 3 SMD lights in my RA and it lights up like a runway landing light inside. :-) Would def help!
Owner: Matt Stewart
09 Ralliart tuned at MPC
13.22 @ 106mph Australia's 2nd fastest Ralliart. (Ill get you captain :-) )
hansmitchel
Postby hansmitchel » Mon Apr 12, 2010 9:10 pm
No worries Hoges ;-)
milobob
Postby milobob » Mon Apr 12, 2010 9:50 pm
I assume a 16 LED SMD for the rear boot will fit? (sportback models)
Goodspeed98
best fit you
Postby Goodspeed98 » Thu Apr 15, 2010 11:51 am
actually you can get a adaptor which can fix the problem ,for the current which is the rated current ,so if you want to replace it with led lights ,an adaptor would help you a lot ,you can take led SMD 3528 which is 0.08W for each led lights ,means you can take the length as you want and the led stripis also can cuttable .
a site may be much better help you
Http://www.ledlightsworld.com/
hope this works ,
regards
