Turbo
your gonna need more then just the turbo kit. im pretty sure the stock turbo runs pretty high psi. at least over 10. you will need at least to get new cams cam springs and cam seats or what ever they are called. need stronger intake manifold possibly higher compression pistons umm what else better bearings basically completely new engine internals. or you risk the possibility of blowing your engine. ORR you can run the turbo at a much lower psi. up until you get new internals.
but i must say the RA turbo is probably your safest option for a turbo with out major problems but you will still need a major ECU reflash or at least have the RA ECU ROM put on your ECU
I am aware of this,
I have serviced for my mate who is ex NSW state rally champion, has been in the top 5 in an asia pacific event, and in the ARC. I have plenty of people and information if I were to do it.
The big issue is I cannot pull my car off the road for weeks to do it, and am strongly considering saving up for an evo
- Skitzo4Bass
Do it lzy_eye... get an evo but yes there's lots of work to be done with putting a turbo in but is rewarding when you have the time and money to do so.. it would be much easier to just buy a car that comes with a turbo already but some people just don't have money (especially myself) to buy and evo or to add a turbo to the existing car..
All i can say is best of luck to you Speedie, i'll be watching out for your progress and admiring your ride
