Are K&N filters really worth it??
Re: Are K&N filters really worth it??
It's not too bad
I assume you ran the motor a bit and got the oil warm before dropping it out
More projects to come
Yes and opened top cap first
Nice
Yeah just went for a drive now to check oil level
Not easy to read as the new oil is very light coloured but I think it's all good new filter & new fully synthetic oil... Should keep me going for a while, will take it to my personal mechanic after new year to give it a full inspection
- lancerdarryl
Oil filters are hard to get off when they've been overtightened or have been fitted without putting a a smear of oil on the sealing ring.When they are fitted dry it's a pain to undo as they feel so tight it's actually the rubber seal sticking to sealing area that the problem.Its handy that the filter points straight down - makes it easy to fit when filled with with oil.
Yeah they are only meant to be on hand tighten not Rock solid, had to buy a wrench to loosen it but even that took time... Yes I put oil on the top and inside the filter just to be safe
Sounds like you're all over it
Yea I have done this before, it's just messy and annoying getting under a car
Got a shed ?
Dig out a pit in it wide enough to squeeze under it
Or
Win the Lottery
Shove a hoist in it pick the car up
Or
Win the Lottery
Yea nothing like that live in a unit block no money
Good work
2011 VRX Sportback
If in doubt, rev it out!
I really like this car it's so nice to drive and comfortable
Agreed
I love driving my lancer
An absolute pleasure to drive
bumblebee wrote:Agreed
Okay another question should I change my spark plugs?
If so should I use standard or like iridium?
Denso Iridium Power Spark Plugs
Or NGK?
WANT the longer lasting but also if I can get better spark/performance?? Tnx
Users browsing this forum: Google [Bot] and 12 guests
