Cheap LED Lighting Thought.
JazzyB
Postby JazzyB » Sat Sep 26, 2009 10:44 pm
yeah, similar thing in mind but my 'double adapter' is a beat-sensor as well ;-)
Thanks man! looks easy now! screw the on-with-the-doors thing ;-)
tadz0rz
Postby tadz0rz » Sat Sep 26, 2009 10:57 pm
Lol, i want to hook mine up to a relay or something so when im getting in the car or opening the door or whatever, they will come on, but as soon as i put it to accesories, they stay on all the time...Which is what will happen if you hook it up the way ive shown you. Unless you put a switch in the line...
Mine has a switch, a very hard to access switch because their actually on the cigarette lighter under the cupholder lol
milobob
Postby milobob » Sat Sep 26, 2009 11:14 pm
Hm, would i ahve to really put in the resistor for the LED footwell wire up?
Postby LZY_EYE » Sat Sep 26, 2009 11:59 pm
milobob, if you use LED lights that are 12v you don't need resistors. It is a good idea to wire in a fuse holder just in case though....
scraverX
Postby scraverX » Sat Oct 31, 2009 3:58 pm
Ah yes... that second accessory socket. Time to flex my electronics fingers I think...
Car & Home audio nut.
Blakey
Postby Blakey » Sat Oct 31, 2009 5:05 pm
SIR-VRX wrote:It's a blue and black thin cable guys. in a white connector. Under the cup holder section.
The other harnesses under the pop-out pocket are for AFS (on the HID headlights, its steering lights) and AWC for the RA's AWD system.
are you sure they are HID in the Aspires and Evos, they don't look like they have washers. so if they dont then they cant be HID's well at least legal ones
tadz0rz
Postby tadz0rz » Sat Oct 31, 2009 5:10 pm
They do blakey.
http://www.caradvice.com.au/wp-content/ ... -front.jpg
hard to see on black, but they are directly under the HID
Blakey
Postby Blakey » Sat Oct 31, 2009 5:12 pm
ah ok are they that bump coming out from the bumper?
tadz0rz
Postby tadz0rz » Sat Oct 31, 2009 5:14 pm
yeahhh
Blakey
Postby Blakey » Sat Oct 31, 2009 5:15 pm
ahh ok i c now
SIR-VRX
Postby SIR-VRX » Sat Oct 31, 2009 11:42 pm
You should know by now Blakey, I'm never wrong ROFL
