Rotational squeaking noise coming from front left wheel
Tywhiteguy
Re: Rotational squeaking noise coming from front left wheel
Postby Tywhiteguy » Fri Aug 14, 2020 6:48 am
Ok, it was while they were off but everyone I’ve asked about it says that’s not normal. Is there nothing holding it to the hub?
2012 ES Sportback USDM Long Beach, CA. RA Snorkel, K&N Drop-In,Custom 2.25 catback with Flowmaster resonator+jdm 4” muffler, Gutted from rear seats back, Pioneer AVH-211EX+12” compact sub :welcome:
Postby lancerdarryl » Fri Aug 14, 2020 11:41 am
It’s normal. The wheel holds them in place
Postby bumblebee » Mon Aug 17, 2020 6:21 am
Your rotor is a "full floating" design
Fairly common type setup
If you Goto remove it , and after the caliper is remived and the wheel removed and I'd you can't get the rotor to budge , there is two small threaded holes in the rotor near the centre
Put a bolt into it and tighten it up and if the bolt is long enough to push thru to the hub behind it, the rotor will pop off
