Philips XTreme Power Headlights
I think it has been said many times on here before, as long as they are UV Blocking Quartz globes. The UV will get them long before the merest increase in heat will....
I have the Crystal Visions, but a different experience with them. Been running since this start of 2008, so I am on a good one! Also have them in the Duc and the Moto Guzzi, for well over two years now.. which is good, since bike run headlights full time....
Good luck with your champion champagne colour!
Tryg
Tryg
- spareparts
the base of the globe will have the correct wattage that the globes puts out..... then i would refure to the box the came in... i ran arctec blues on my statesman and im shore they 55w low.... in sayin that i had after market head lamps in it so it wasnt running the h4s i had to use h3s
the voices may not be real, but they have some pretty good ideas
:D
backfire_88
Front of car:
Front turn signal light: 21watts bulb: WY21W
Head light, high beam: 60watts bulb: 9005 HB3
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
front foglight: 55watts bulb: H11
Front side marker and parking light: 5watts bulb: 168/194
Side turn signal light: 5watts bulb: 168/194
REAR of car:
High mounted stop light: Led
License plate: 5watts bulb: 168/194
back up light: 21watts bulb: 7440
tail light: 5watts bulb: W5W
tail and stop light: 21/5watts bulb 7443
rear turn signal: 21watts bulb: 7440
rear sidemarker: 5watts bulb: W5W
INSIDE CAR
trunk area: 5watts bulb:----- 3022
dome light: 8watts bulb:----- 3022
REAR of car:
INSIDE CAR
- bungfritz
- Lancer ES/EX
backfire_88 wrote:Hey guys!
I am kinda of confused. Should I purchase H4 or H7 Lamp for my Lancer09?
Cheers
Make sure you purchase the HB4 not h4 as they have a different base and connection.
I accidentally bought a set of h4's before reading carefully that the lancers have a hb4 fitting. Lucky my parents car have headlamps which take h4's so I'll install it in their car when I have time.
I'm looking at replacing my stock bulbs - the Philip's Crystal Vision that people have, is it the 4300k (model 9006). I have found a set on eBay for $60 delivered with free pair of T10 parker bulbs, who knows how good they are anyway. Here's the listing if anyone's interested: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0473352908 . Do these meet ADR compliance?
Are these the right Navara Arctic Blue's? Say H4, not HB4.. http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0083121151
- scraverX
I just put in Narva Arctic Blues. I tend to notice details of things an in this case it was the printing on the 'plastic' base fitting where it angles. Mine list two(2) wattage numbers on both the high and low.
One set of numbers is the 51W Low, 60W High.
The other set of numbers are listed as "Blue Point" which are the 55/65.
@cyssero: No, that aint our bulb, refer to tryg's post. That's direct from the manual.
Repco and autobahn both have Narva's, though they don't often have the HB3 and HB4 in stock as they're somewhat unique fitting to New Japanese cars. I got lucky and the Repco where I got mine was able to bring in a set from another store.
Edit: I'd just like to note that getting at the high beams is a touch fiddly so exercise patience.
Car & Home audio nut.
Thanks for the clarification scraverX.
Will make sure I get HB4s. How are you finding the Arctic Blues? May be the ones I end up with because they have the ADR compliance (unsure about Philips).
EDIT: Looks like I can get Philips Blue Vision 4k for under $50 delivered with parkers. I'm guessing there is a big diff between the Crystal and Blue though, Blue give the 'Xenon' look apparently. Just gotta make sure I'm getting 51w not 55w. Is there a huge problem with using 55w in 51w? Some earlier complaints about heat but looks like a few people are using them.
- scraverX
@cyssero: I haven't really taken a good chance to get a proper idea; only a quick drive to the shops on lit streets (no high beam) since fitting them.
The light is certainly noticeably "whiter" and reaches further.
Edit: Ok, just did a run down an unlit stretch and here's my assessment of the Narva Arctic Blue's. How much you notice the effect of these bulbs will depend a lot on the roads you drive and the quality of the lighting on those roads.
- Well lit major roads and around major intersections you won't really notice them.
- In older suburbs with sparse lighting, or lighting away from the roadside, you'll notice them more.
- Unlit roads is where they really shine, especially if you take the slight extra hassle of switching out the highs. Reflective lane and side markings are very clear as are signposts (especially the newer kind) and the light reaches a lot further.
- Disclaimer: this is just my opinion and opinions vary.
- exaltd
@ cyssero:
This was my complaint. As I have found out now, after months of using them, there shouldn't be a problem with heat. I posted them when I first got them, and found that they were a bit hotter than normal, however nothing has happened since then, and they work perfectly fine. No side effects.
Use the 55w if you can. It's easier to find.
-EXALTD-
-EXALTD-
Thanks heaps extaltd + scraverX.
Has anyone had any dealings with the Philips Blue Vision? They're 55w, 4000k and about $40-50 delivered for 9006 (HB4), same price for 9005 (HB3). http://www.powerbulbs.co.uk/zoom.asp?prod=10&image=1 - they look like this http://www.autolamps-online.com/halogen/bvstdcentre.htm .
I reckon I might go for them, they're priced well and have ADR approval.
- scraverX
That is a good price. I paid $70-80 for the Narva Arctic Blue's but then I don't have an easy way to buy online short of direct deposit so I prefer to source stuff locally and pay cash where possible.
