LED Shed lights
Re: LED Shed lights
Postby bumblebee » Tue Aug 15, 2017 8:10 pm
I cant see why not
So long as the output is 12v your right
Ronan.Butler11
Re: LED Shed lights
Postby Ronan.Butler11 » Thu Aug 17, 2017 10:58 pm
Cant see why not. From taking apart some of those lights its just a standard Active and Neutral. Just gotta suss out how many could be powered off the 1 solar panel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re: LED Shed lights
Postby bumblebee » Fri Aug 18, 2017 6:11 am
With a bit of luck in the manual that cane with the lights it should tell you the voltage/amperage its output is.
Led strips 12v ones like i have in the boot if my car use bugger all current/amps.
You should be able to run at least a few meters off it. And becuase it runs rechargeable AA batteries you can upgrade those anytime you wish
Return to “Electrical”
