Hard Wire Dash Cam / USB Port
Postby SAM-24A » Wed Jan 06, 2016 5:22 pm
Aspir3 wrote:The gropro should come with a plug that needs to go to 12 volt with an inbuilt inverter.
That "Should" may be the case with GoPro ... An inbuilt inverter plug that connects direct to 12VDC ..... I don't know *noidea*
But All/Most other GPS/DashCams Units are rated @ 5VDC.
Postby aspir3 » Wed Jan 06, 2016 5:43 pm
SAM-24A wrote: That [color=gold:f1f3a27dd2]Should[/color:f1f3a27dd2] may be the case with GoPro ... An inbuilt inverter plug that connects direct to 12VDC ..... I dont know *noidea* But All/Most other GPS/DashCams Units are rated @ 5VDC.
Sam here is the [url=http://www.ebay.com.au/itm/DC-12V-to-5V-3A-Step-down-Converter-Regulator-to-2-Female-USB-Output-for-Car-/262129046579?hash=item3d081bd433:g:pOoAAOSwwbdWO1t0[url]link[/url] in the original post for the inverter that I was suggesting to wire directly to the battery power source from behind the fuses.
Return to “Electrical”
