My Daily
Postby SAM-24A » Sat Nov 14, 2015 9:12 am
@ Haza92
The extender pipe "sleeper" correctly refereed to is commonly known as a "02 SENSOR CEL ELIMINATOR" (or words similar)
This bent pipe essentially removes the 02 Sensor from the path of Exhaust Flow & houses the 02 Sensor in a pocket of Clean Exhaust with the pipe itself. (simple really).
These can be found/purchased from most Performance Exhaust Shops.
Goggle: "02 SENSOR CEL ELIMINATOR" for pics & suppliers.
I know this works, because it has for everyone that used one :D
Postby sleeper » Sat Nov 14, 2015 12:33 pm
which is to me is a waste of money Sam, as putting in a 2 dollar bung and duct taping the sensor to the brake lines/chassis achieves exactly the same result,.
both methods remove the sensor from the over rich exhaust environment, so therefore no CEL.
the problem with having 1 CEL even though u know what it is Harley, is that if u get a real bad CEL at the same time it wont show up on your info screen
Haza92
Postby Haza92 » Sat Nov 14, 2015 12:42 pm
Thanks lads, yeah the CEL has been giving me the S@#TS since I put the cat on. Either way at least I know now there are a few alternatives to sorting it out. thanks heaps :)
Haza92
Postby Haza92 » Sat Nov 14, 2015 12:45 pm
sleeper wrote:which is to me is a waste of money Sam, as putting in a 2 dollar bung and duct taping the sensor to the brake lines/chassis achieves exactly the same result,. both methods remove the sensor from the over rich exhaust environment, so therefore no CEL. the problem with having 1 CEL even though u know what it is Harley, is that if u get a real bad CEL at the same time it wont show up on your info screen
Completely agree there. Is the Hole sizing M18 do you know?
Postby sleeper » Sat Nov 14, 2015 12:47 pm
nope, dunno :) sam might
Haza92
Postby Haza92 » Sat Nov 14, 2015 12:54 pm
Asking because the apparent universal sizing is m18. Just wanted to clarify :)
Postby sleeper » Sat Nov 14, 2015 12:55 pm
sam is the thread pitch guy :P
Postby SAM-24A » Sat Nov 14, 2015 2:40 pm
Haza92 asked:
"Correct"
M18 x 1.5mm Thread pitch. (International Standard for all 02 Sensor's)
This thread is also a common Spark Plug thread size.
Haza92
Postby Haza92 » Sat Nov 14, 2015 3:01 pm
Awesome cheers for that :)
