RA SST fluid change with warranty work
Prof_Bowser
Postby Prof_Bowser » Mon Aug 31, 2015 8:10 pm
I've had a look through the service manual and it states that you need to remove the oil pan assembly in order to replace the mechatronic unit. It then goes on to say that if the pan assembly and internal components are repaired then NEW fluid is required.
I think this should get me over the line if Mitsubishi Customer Relations doesn't help me out.
Now I just need to quote the page and explain how I found it without infringing on copyright haha
