Michael from Sydney
solo
Postby solo » Fri May 09, 2014 11:23 am
Welcome to CJ
shadow-vex
Postby shadow-vex » Fri May 09, 2014 3:15 pm
Welcome, if U just want a general service do it yourself, just buy the oil and oil filter. There is only 5 bolts that need to be undone on the plastic underneath, which gives you access to the oil filter and sump plug. And you shouldn't need a new air filter just give it a good shake if you don't have a compressor, if you do, then just use an air gun on it. If you want to take your car to mechanics maybe post here what the issue is, as member are well versed when it comes to issues with the cj.
kay christensen
Postby kay christensen » Fri May 09, 2014 5:01 pm
Welcome :)
(cj-red)
greywolfe
Postby greywolfe » Fri May 09, 2014 7:12 pm
The scary part is going to be stumping up for the sst fluid change. What's the interval on that again?
Zaphod
Postby Zaphod » Fri May 09, 2014 9:29 pm
:welcome:
Users browsing this forum: No registered users and 126 guests
