LANCER PAINT CODES
SIR-VRX
Postby SIR-VRX » Sat Oct 31, 2009 11:13 pm
Post some pics of yours, as it doesn't sound like any Aspire I've seen lol
Not saying you're wrong, just interesting how it is painted!
Postby aspir3 » Sat Oct 31, 2009 11:17 pm
SIR-VRX wrote:Post some pics of yours, as it doesn't sound like any Aspire I've seen lol
How do I do that, sorry I have tried
[/url]
SIR-VRX
Postby SIR-VRX » Sat Oct 31, 2009 11:27 pm
If you upload an image to Photobucket (or ClubCJ image hosting) you get the URL of the image and ut it between the tags [img]and[/img] so it would look like this:
Code: Select all
[IMG]http://i290.photobucket.com/albums/ll259/cyruschrono/RA.gif[/IMG]
Turns into
Postby aspir3 » Sat Oct 31, 2009 11:48 pm
Shit, I did it. :o
The 2 centre grills are original. Fog lamp surrounds I have changed
SIR-VRX
Postby SIR-VRX » Sat Oct 31, 2009 11:51 pm
Ok, so are you saying that the inner grille (mesh part) is the same colour as the car, or similar to it?
I can see the outer (surround) is chrome, as are your foggies now.
But I thought the inner grille mesh was silver/chrome colour also :S
Postby aspir3 » Sun Nov 01, 2009 12:02 am
SIR-VRX wrote:Ok, so are you saying that the inner grille (mesh part) is the same colour as the car, or similar to it?
It is hard to see, but if you look at the bottom grill on the drivers side where it is solid it looks more silver then the body. It is different to S18
SIR-VRX
Postby SIR-VRX » Sun Nov 01, 2009 12:06 am
That is probably because the grille isn't meant to be body colour. It is meant to be a silver/chrome grille. So there would be no paint code for that.
Postby aspir3 » Sun Nov 01, 2009 12:20 am
Yes you are right, but it must have a code. All original paint have a code. The identification plate have only the body colour code on them. Mitsubishi should know the colour of the grill but they could not tell me. I was hoping someone experienced the same problem but found the answer
SIR-VRX
Postby SIR-VRX » Sun Nov 01, 2009 12:23 am
It is made in the factory, the plastic is that colour. It is not just painted on... Not from what I can tell anyway... Even so, a good paint shop can match it up, they have those scanning things now they use to get it perfect
Postby aspir3 » Sun Nov 01, 2009 12:30 am
You are right again. I did not think of coloured plastic. I should know too used to work as a plastics toolmaker supplying car parts. I have not seen coloured plastic on car components. I will check it out in the morning.
We did colour match the fog lamp surrounds as you can see, but would have been easier and more accurate with a code.
SIR-VRX
Postby SIR-VRX » Sun Nov 01, 2009 12:33 am
I'm always right :P
But I am intrigued, I'm fairly sure it is coloured in the plastic.
You supplied parts to which manufacturer?
Postby aspir3 » Sun Nov 01, 2009 12:40 am
SIR-VRX wrote:I'm always right :P
I use to work for Exacto plastics 98-03. They recently just closed, went bankrupt :D
They supplied parts to Holdens, Mitsubishi, and Fords
Mez
Postby Mez » Tue Dec 01, 2009 5:25 am
which one is the plain black you get out of the 8 choices or whatever
for a vr lancer ?
SIR-VRX
Postby SIR-VRX » Tue Dec 01, 2009 6:33 am
X42 I believe
86MIM
Postby 86MIM » Tue Dec 22, 2009 10:45 am
SIR-VRX wrote:X42 I believe
This be the same for the ES?
All I know is it's still black LOL...
kii
tykkään kiiltävä, nopeasti ja se on saanut olla ähkyä.
_________________
ClubCJ Lifetime Member #86
Users browsing this forum: Google [Bot] and 41 guests
