Problem with 1st to 2nd gear.... Manual
Postby SIX » Sun Feb 24, 2013 9:28 am
Not excitably sure what adjustments all they said was something was too tight and that they had to loosen it up
denzza
Postby denzza » Sun Feb 24, 2013 11:10 am
Thanks alot guys! You have helped me alot :) Im going to take it to another place and see whats going on.
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
darren1011
Postby darren1011 » Sun Feb 24, 2013 11:55 am
TrojanHorse wrote:Crunching could def be clutch cause it wont be disengaging properly. But yeah that popping out, I would say again, IMHO highly unlikely clutch. Can I take it to a gearbox specialist?
Get one to drve it and ask. To look at the box meanss dropping it out and opening it up which means at least a bearing and gasket kit. I'm not even certain they have a top plate. I'd have the linkages checked first, probably not by a dealer
denzza
Postby denzza » Sun Feb 24, 2013 3:16 pm
So i should tell them to look at the linkages! and make sure they are okey?
Because i WD40 the cables yesterday, that are connected to the throw of the stick! and its was all good till today :( so yeah its something with that!
darren1011
Postby darren1011 » Mon Feb 25, 2013 12:08 am
Geting somewhere now. Any kind of external likages are usually the first thing to go
denzza
Postby denzza » Wed Feb 27, 2013 12:43 am
I called up Mitsubishi again, and i asked them i think the linkages are loose or something. But he told me theres not to adjust lol and if they were to replace it, apparently its not under warranty :/
He kept telling me the clutch is worn out !!
Im going in 2 days to get a 2nd opinion :)
Users browsing this forum: No registered users and 148 guests
