merlin tune
Latino_Ralliart
Postby Latino_Ralliart » Thu Nov 22, 2012 10:32 am
SEB15 wrote:[color=red:0102b81cb4]Also bare in mind when you have to return the car to stock tune ( for dealer servicing) you will have to take out the boost pill and put back the stock pill as well! A boost pill with a stock tune can create internal damage to the engine [/color:0102b81cb4]
Your going in to get a simple service............ Why will you have to take everything off?
The service department of my local Mitsubishi is so busy I doubt they have the time to detect tunes etc.
Latino_Ralliart
Postby Latino_Ralliart » Thu Nov 22, 2012 11:26 am
Tell us all how it goes.
You should also look into lowering the car also. The standard stance is 4WDesque.
merlin
Postby merlin » Thu Nov 22, 2012 11:28 am
If you are going to a dealer for servicing and want to keep life simple, go for a revised boost pill. Any pill with a bore hole size smaller than stock will give more boost when tuned.
The pills I use I machined myself and have a 0.7mm hole, which is a bit smaller than those I have seen from US suppliers and a lot smaller than stock. This just gives it a bit more boost tuning range.
Beeble
Postby Beeble » Thu Nov 22, 2012 12:31 pm
IMO a lot of the US boost pills do didly squat. the boost increase almost isn't worth the hassle of installing it.
But it sounds like MerlinMade pills would fare much better.
http://BeebleTune.com
