thanks guys.
was thinking of blacking out the bottom lip of my bumper.i think the plasti dip would be easy to do then vinyl sheet
Plasti Dip Blackout
- BUZZ_QWERTY
Lewhite wrote:thanks guys. was thinking of blacking out the bottom lip of my bumper.i think the plasti dip would be easy to do then vinyl sheet
There is a lot less prep work if you just wrap it in vinyl, especially if it is pre-cut. Basically just clean and apply. Btw Nice job Frosty, you did an awesome job!
Turbo - Yeah, Performix (the manufacturer of Plasti Dip) also make top coats to add metallic fleck or a sheen - much like clear coat goes over the top of automotive paint; glossifier goes over plasti dip.
Lewhite - I would definitely be using plasti dip for that one, vinyl is great but personally I like the control of plasti dip.
Buzz - Thanks man, appreciated
2.0L - K&N Typhoon SRI - High-Flow Exhaust System - Merlinised
did mine today!!!!
its a great product to use especially for the bottom lip.to only problem i found was peeling the tape at the bottom of the lip cause the material is elastic,it doesnt cut of properly when u peel the tape and i didnt wana use the pen knife as it will scratch the paint.but doesnt matter it at the bottom so u cant see it lol
Terry, it shouldn't be too much of an issue provided you apply nice thick coats on a well prepared surface.
If you half-ass the prep work and don't get a perfectly clean panel (even fingerprints will give it a place to start lifting) it won't turn out the way you want.
I've washed my car 3 times since I did this mod and it's showing no sign of lifting.
