What used spark plugs look like....
Postby SAM-24A » Tue Oct 16, 2012 4:30 pm
All the Technical Info on Spark Plugs ..... click on the highlighted headings.
darren1011
Postby darren1011 » Sat Oct 27, 2012 2:19 pm
SAM-24A wrote:All the Technical Info on Spark Plugs ..... click on the highlighted headings.
Interesting to note after mods, if I change to a CAI and intend on getting headers 4 2 1 and then adding a full exhaust later, while my plugs are about due now, would it be smart to change drom std? Your opinion appreciated
Postby SAM-24A » Sat Oct 27, 2012 4:24 pm
@ Darren.
NO .... there is no need to change your Spark Plugs from the Standard Range.
There will not be any significant operating temperature difference effect on your engine with those mods to warrant a Heat Range change of your Spark Plugs.
Just replace the genuine NGK Iridium Plugs found in your engine at present.
2.0L = NGK FR6EI
2.4L = NGK FR5EI
These are the best value for money & performance available for your superficially modded engine.
darren1011
Postby darren1011 » Sat Oct 27, 2012 4:42 pm
I thought as much, no cam change etc
