Brake pads for ralliart
All Brake Modifications.
Craker
Postby Craker » Sat Sep 29, 2012 3:36 pm
Front pads are getting low on the ra and now it's time to change them and the rotors while im at it. Looking at rda slotted fronts, green stuff pads and dot 4 brake fluid. The local brake place is doing the work. Anyone using the rda rotors, are you happy with them, any problems.
enkei sc 22 wheels
Momengah
Postby Momengah » Sat Sep 29, 2012 6:21 pm
DBA front rotors seem to be the one's most people get. Though they only make them for the front on our RA's. You'd need to get RDA for back
-Cosworth Air Filter
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
-Ultimate Racing UPICP & LICP
Tweak
Postby Tweak » Sat Sep 29, 2012 6:37 pm
iam in need of some new pays aswell pretty sure ive cooked em real good. still about 30% left but it does SFA when the get hot
Postby sleeper » Sat Sep 29, 2012 7:06 pm
i have remsas front and rear, theyre yet to fade or overheat.
but dusty like all performance pads.
Kal777
Postby Kal777 » Sat Sep 29, 2012 7:53 pm
should also keep in mind that any pad on a slotted or drilled rotor is going to cause more brake dust than the same pad on a standard rotor. the point of the slots is to lightly shave the surface of the pad at each pass to stop build up of glazing.
also, track pads will wear out a rotor faster than a street pad.
Craker
Postby Craker » Sat Sep 29, 2012 11:52 pm
It's a daily driver so I want good cold braking without having to get warm but more confidence when attacking mountains without too much noise or harsh on the rotors, so a good compriomise, at a good price. Ive sent a few emails to brake places in my area and I'll see what they offer and what combination of pad and rotor they can recommend.
enkei sc 22 wheels
Craker
Postby Craker » Mon Oct 15, 2012 8:51 pm
Got the rda slotted rotors and red stuff pads on the front. Done about 200 ks on them so far and still bedding them in. So far on light braking already feel great even when cold. There is no noise at all. I will post another review after 1000 ks when they have bedded in properly.
enkei sc 22 wheels
Postby sleeper » Wed Oct 31, 2012 3:39 pm
probably GSL rallysport
Postby SAM-24A » Wed Oct 31, 2012 3:46 pm
Joe ....
QFM HPX pads = Good Choice ... *thumb*
I didn't bother looking for them in Sydney because our sponsor GSL Rally Sport has them very competitively priced for club members.
They're located in QLD, so the shipping cost is marginal.
Postby sleeper » Wed Oct 31, 2012 3:47 pm
Remsa pads are the pinnacle of European quality. Remsa are rated to 650 degrees (versus 550 for something like QFM HPX or Bendix Ultimate), whilst still delivering VERY low rotor wear and noise! Remsa come with noise reducing features such as a relief grooves and shamfers in the pad material, as well as a soft backing shim as standard. Remsa also come standard with the electronic wear sensors where required!
quote from GSL.
i use them, they cant be faulted
http://clubcj.net/viewtopic.php?p=271918#271918
bobcrusader
Postby bobcrusader » Sat Nov 03, 2012 9:53 am
Just replaced my OEM pads after 52,000kms. Went with EBC Red on the front and green on the back. Had braided lines installed on the front while they were there. High temp fluid went in as well. Don't want a repeat of my boiled fluid, smokin' brakes, "OMG is it going to stop?" Sandown experience again.
- 2009 Lancer Ralliart
- Boostpill + Tune
- Upgraded intercooler + pipes
- Turbo XS Catback
- Drift BoV
- Blitz Air Filter
bobcrusader
Postby bobcrusader » Tue Nov 06, 2012 4:45 pm
Benefits of dot4? Sounds like a question to ask the brake place.
I just asked for high temperature fluid, since the OEM stuff boils pretty easily early into a track day.
- Boostpill + Tune
- Turbo XS Catback
- Drift BoV
- Blitz Air Filter
Return to “Brakes”
