People with coilovers, please read on to help me
cj_sx_2011
Postby cj_sx_2011 » Thu Apr 19, 2012 1:19 am
good explaining that ray, i dont know anything of those things, so itd just be pre set my someone who knows alot about them, but i will definatly look into the bc's for sure and see what they think are the best, but do not want the race ones and that.
Dire
Postby Dire » Thu Apr 19, 2012 1:20 am
rthieu wrote:it would be hard to feel the difference between a damper setting of say 15 out of 30 compared to something close like 17 out of 30, so essentially those 2 extra levels of adjustment arnt really necessary.
Bigger is better though :P
cj_sx_2011
Postby cj_sx_2011 » Thu Apr 19, 2012 1:29 am
the race series isnt the track ones are they? i think i will most diffently look into the ones... BC Racing Coilover Suspension Kit - Mitsubishi Lancer CY4A
scraverX
Postby scraverX » Thu Apr 19, 2012 2:42 am
I've got the BC V1's myself.
Cost me $1600 fitted - few reasons; cost to have them trucked in from sydney, had to take my sub box out to fit them (extra labour)
Difference between the V1 and the BR (gold) is the diameter of the damper which is slightly bigger on the Gold.
Mine are set just under half way, ride is nice just have to be careful on speed bumps. I didn't want them set too hard to allow for less then perfect roads.
Canberra has a LOT of roundabouts, that's where I tend to notice the coilovers.
Car & Home audio nut.
cj_sx_2011
Postby cj_sx_2011 » Thu Apr 19, 2012 9:59 pm
top name rick :P
thanx for that man, i got the bc coilovers recommend to me, and he didnt give me the name as he wanted to do alittle more research to see which ones were the right ones for my car,
but seems the best ones for my car are the ones all you guys have said to me.
empror
Postby empror » Fri Apr 20, 2012 9:29 am
i havent yet purchased my coilovers, but you should also have a look into yellowspeed, they seem about the same price as BC (around 1300, without install) and they seem to be quite good. some guys i talked to (not lancer drivers) said that when they had issues with their BC's (just unlucky, these things happen) that BC didn't want to hear from them..
Yellowspeed and BC from what I hear are about on the same level. here's whats in the yellowspeed ones:
http://www.yellow-speed.com/dynamic-pro-sport.php
Postby ofey » Fri Apr 20, 2012 10:47 am
Here's another way of looking at it.
From what historical stories I've heard, BC has single handedly been responsible for bringing down the price of coilovers.
Before BC released their own range of coilovers they were simply an OEM manufacturer, producing for Pedders amongst others.
So uptake wise, for value, alot of people have gone for BCs.
Some NOT even realising their coils made which carry other brand names on them are actually also out of the same factory.
BC's market penetration is very high, so for every 20 satisfied customers, there will be one failure. Even then it may be hard to attribute the failure.
But just to err on the side of caution, none of the people who have gone BCs on this forum have had problems. That's a pretty good endorsement in my book.
empror
Postby empror » Fri Apr 20, 2012 11:01 am
Valid points, I wasn't slamming BC or anything by the way, just throwing in conjecture that I've found in my researching for consideration's sake, but yeah you're right, BC are a reputable name for a reason, they wouldnt be there if they were selling dodgy quality products. And from everything I've heard, the Yellowspeed are almost exactly the same as the BC's anyway haha. So it's really neither here nor there I suppose.
Postby ofey » Fri Apr 20, 2012 11:14 am
Yellowspeed and BC are both from Taiwan.
So really 2 peas in a pod.
But if you look at the size of the operation, BC is significantly larger.
Postby SAM-24A » Fri Apr 20, 2012 12:31 pm
@ Chris aka empror .....
For Spirited Road Use & the occasional Track Day for fun .... then go for the BC's .....
Read this thread: BC Coilovers
Gold version ..... BR Design RA Series ..... B-19-RA ....
Price: $1299 .... Free Australia-Wide Delivery!
This model has enlarged shock absorber cartridges with specially designed shock pistons and rods to provide a broader range of damping force.
Merlinised AspiRe 2.4L
empror
Postby empror » Fri Apr 20, 2012 1:16 pm
thanks sam! those are the exact uses I'm looking at, "spirited" road usage and potentially track days later on.
much appreciated :)
it'll be a fair way down the track though, I just ordered super circuit headers :D
Dire
Postby Dire » Fri Apr 20, 2012 3:05 pm
Idk if you all do but I have extension things on my rears so the damper adjusters are in my boot. I had some fun messing around with the settings but decided hard was better than violently bouncy :P
Does having them set harder shorten their life though?
scraverX
Postby scraverX » Fri Apr 20, 2012 3:23 pm
I'll just add a little note for those of you doing your research on coilovers in general.
Get whoever does your wheel alignment to give you a print out. That way, if you have issues down the line and have to take it else where you have a record.
Even something as simple as switching tire brand/model can really change the feel of your car. :) (More so for those of you with wider wheels.)
cj_sx_2011
Postby cj_sx_2011 » Fri Apr 20, 2012 3:57 pm
never heard of yellowspeed.
i am thinking of either going a 18s with a good tyre on it, or just replace the stock tyres with top of the line yokoz or toyos or something when i get the coilovers.
scraverX
Postby scraverX » Fri Apr 20, 2012 4:05 pm
I run 18x8 ET38 rims and just got a set of 4 Bridgestone RE050A's in 225/40/R18 :)
Factory fit on HSV's and WRX's apparently.
Nice and quiet for a performance tire but not cheap.
Users browsing this forum: No registered users and 149 guests
