do u need airflow metre thing when changing the induction?
Glenn
Postby Glenn » Mon Apr 16, 2012 10:14 pm
Should be the same stock intake for all years.
It sounds like your after the MAF housing tube not an actual 2nd MAF (the actual sensor - rectangle looking thing with 2 allenkey bolts)
If you cut out the MAF tube section then couple that to your custom pipe work you should be good. Or Custom fab a pipe with a hole in it so you can bolt the sensor to it. You'd want to try and keep the pipe diameter same as stock.
Even by doing that, chance are you'll be getting a different flow of air to the engine which can upset the ecu if its outside the working ranges.
the MAF calcs are tuneable but will take a bit of logging and know how.
For example buying some aftermarket intakes for an evo x replace's all the pipes for more flow but by doing so you have to tell the ecu you're running a bigger pipe or else fuel trims go out the window
Speedie
Postby Speedie » Mon Apr 16, 2012 10:22 pm
I personally think you can get rid of the MAF as long as you can tune for its removal as all Lancers have MAP sensors as well.
cj_sx_2011
Postby cj_sx_2011 » Tue Apr 17, 2012 1:51 am
ill definatly keep that in mind glenn,
daniel, do they really. i didnt know that, does that mean it can take the afm out and then get it map sensor tune for that, then also if i want to put it back to running the stock intake with the afm it will work out alright??
thanx for all the comments ppl, i really apricate it.
Speedie
Postby Speedie » Tue Apr 17, 2012 5:43 pm
Powertrain control, Map sensor
ELECTRICAL »Powertrain control
Mitsubishi › Lancer › 2008-2010
List Price : $220.03 USD
Lancer, From 4/1/08
Mitsubishi › Lancer › 2009-2010
List Price : $233.07 USD
Taken from US parts manual. So if you can find a tuner that has the ability to do a MAFless tune for a lancer than very possible . If you know your way around ECUFlash you could achieve the same result. Tricky but not impossible.
If you were to tune for MAFless you would have to retune when you replaced the MAF
cj_sx_2011
Postby cj_sx_2011 » Wed Apr 18, 2012 1:51 am
hey thanx for that, and thanx all, but i dont know what im going to do now. but ive seen a few ways to go, so ill see what i decide to. thanx again.
Users browsing this forum: No registered users and 110 guests
