Help needed!: ASC "Service Required" Error
- lancerdarryl
Re: Help needed!: ASC "Service Required" Error
ECU fix in Melbourne were the ones you’re looking for but they seem to have disappeared.The next best option is COOLDRIVE,last time I had one done with them it was around $1000.Takes a week to get it done and the labour to R&R the unit and bleed the brakes should only be 1 hour
thanks Darryl again for your help.lancerdarryl wrote:ECU fix in Melbourne were the ones you’re looking for but they seem to have disappeared.The next best option is COOLDRIVE,last time I had one done with them it was around $1000.Takes a week to get it done and the labour to R&R the unit and bleed the brakes should only be 1 hour
Went to mechanic this morning and he ran the fault codes again.. There were 4 of them.
C2104
C2200
C1200
C1204
Mechanic called Cooldrive (thats who he has used in the past) - one error code C2200 ?? means apparently CPU is fried.. Not repairable.
So looking to ebay now for another unit Number off the unit is 4670A561... few there.
- lancerdarryl
Good luck.A second hand unit will work out cheaper for you
lancerdarryl wrote:Good luck.A second hand unit will work out cheaper for you
Yea not much choice
