if you have a look at this doc https://docs.google.com/file/d/0B-fnvWb ... view?pli=1 it is the GETRAG manual for the 450 and 470 box but on the 9th page it lists the different names for the manufactures oil,easily
Transmission Fluid Type: BOT 341
Ford part number: XT-11-QDC
Volvo part number: 1161838
Mitsubishi part number: MZ320065
Mitsubishi calls this Dia Queen SSTF-I
Approximately $28.00 for 1 liter
dont know if this helps but the link is a good read.
SST Fluid comparison - Results
Castrol Transmax Dual and Bot 341manufactured by Castrol.
Under brand Bot 341 are made to order for the official Mitsubishi service centres.
Under the brand Transmax Dual this fluid a few years later went into retail sale the overall composition of the fluids is almost identical. Transmax Dual has a slightly higher viscosity to better resist over heating.
The above was translated from a european site, they seem to think Transmax Duel is a better fluid
is there a "how to" some where on this guys?
i`ve found 2, which do u think is more accurate?
http://goo.gl/jpcWUp evoM
or
http://goo.gl/1NWGb0 evoX
or
- bunnishiwa
They're both essentially the same, except sst's MY10 and back have 3 drain holes, MY10 and after have only 2
It is easy to do yourself if you have a spare 4 hrs or so. I used 1ltr water bottles to measure what came out to replace the exact amount of fluid
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
- Lowered on Kings
yes you need to remove both, as the bolt is under the battery tray, and i think you have to remove just the snorkel from the air box, you will need a 8mm allen key
http://www.evoxforums.com/forums/showthread.php?t=35444
- bunnishiwa
Just the snorkel & battery to get to the fill hole
- Lowered on Kings
- Lowered on Kings
Hay guys, I will be buying a 20L drum of the Castrol transmax dual, and looking to drop the fluids this coming weekend.
I am looking for someone to go half for the castrol fluid?
If anyone is interesting, I will go half with you, so 10L for half of what I will pay. I have been quoted around $360ish mark GST inclusive.
PM me if interested.
Thanks
Thanks
