Okay so mines all installed and working well...
one question i have is for the power pro... i have the power hooked up to the hazard lights, but the unit still says its turning off when i turn the car off... ive given the car a shake and it doesnt seem to start recording a 'parking incident' what am i missing?
*CLOSED* Dashcam Group Buy Rd 4.1 Aug'14
Set it up correctly? Look at the instructions, make sure the switches are set up for how many hours you want it on, and what voltage you are on, 12 or 24... then make sure the main switch is on.
I thought the On/Off was a "Always On Override" switch at first, but its not. So make sure that is on. I also noticed that If I turned the car to acc but don't start it, then turn it back off again, It turns off. I think its because there is a slight surge that is causing the relay to flip back and forward and get stuck off...
- SchumieFan
- Lancer ES/EX
- JaZira5
- Lancer VR/GT
SchumieFan wrote:Never mind, ive realised after watching a video if got the acc and batt wires reversed... whoops... lucky easy fix
Glad you managed to find the issue. I was thinking the problem was something along those lines. Since mine is working as it should.
citris.87 wrote: I thought the On/Off was a Always On Override switch at first, but its not. So make sure that is on. I also noticed that If I turned the car to acc but dont start it, then turn it back off again, It turns off. I think its because there is a slight surge that is causing the relay to flip back and forward and get stuck off...
When I have the Magic Pro switch to ON, its constantly ON and not changing from ON when I turn the key. Though when I have the Magic Pro switch to OFF, and I don't have the key in the barrel the Blackvue only activates when I turn the key to ON. Though, in both instances when I turn the key to ignite the engine it always turns the Blackvue OFF then ON, due to the surge. Its like the radio being turned on before the engine goes on.
Either way, I'll give it a good look to see if what has happened to yours happens to mine. ^_^
OK so we're back with Round 2.
Seller wants to do an X'mas Special.
The prices I've been quoted are pretty good for Australian Stock. For < 20 pieces we're A$21 cheaper than eBay.
Once we cross 20 pieces, the discount will go double!
We're also seeing RColt.net and FT86 clubs join us. So it may not be too hard to get to this number.
Let's see how we go... .
- Mystique
After what happened the other night... I really think I need to invest in one of these... may have to wait until after Christmas and after I get my baby fixed though
Damn!
If it flies with the rest of the car club reps, the price is going to be stupid. So get some money put together!!
I'm assuming you mean rear FACING.
The DR-550GW is a dual cam version so in the box you get 2 cams in the box... .
