DVD Map based MMCS A01-A04 - The Definitive Guide for CCJ
Saw this youtube video about the European MMCS which looks the same as the American one. I think we're the only ones that missed out on those systems.
[youtube]http://www.youtube.com/watch?v=WOGmVbU4ReA[/youtube]
Some points to note:
1. They are now at E-06. Why are we still only at A-04? I know E stands for Europe and A for Australia but they've revised theirs a few times now. Or is it more buggy. Whatever it is I want bigger number!
2. OK say they have more features, I can accept but why are their graphics so much nicer for the features we share?
Why does their Altimeter and barometer retain data from before? Ours lose all data when we shut down.
Look at 0:45. Look at their GPS Satellite tracking screen!
Look at 4:23. You can choose between a female and male voice. I want Darth Vader's voice!
Look at 5:03. Look at their speaker setup screen!
Sadly we'll never get this here.
- hansmitchel
To be honest I'm not too bothered about USB integration.
I'm pissed about no BT streaming though.
- The X
ofey wrote:1. They are now at E-06. Why are we still only at A-04? I know E stands for Europe and A for Australia but theyve revised theirs a few times now. Or is it more buggy. Whatever it is I want bigger number!
One can only imagine the E Vs A designations are just s/w load to indicate what region the GPS maps are loaded/licensed for. i'd be guessing the update DVD would have the E* base code for the actual MMCS operating system and also seperate directories for all the Euro map data.
Now if one could get their hands on an E* disc with firmware update, get the base code for the firmware, slipstream it with the A-version GPS maps and load it.... of course the small risk is that you brick your MMCS if it doesn't like it..
- The X
ofey wrote:In theory that sounds the way to do it but I dont think practically its viable.
Unless the chipset on the mainboard is different CPU, different GPS chip, different NVRAM FLASH drive then you might come into problems. Only way to find out would be to open both units and compare the chipsets and confirm.
The units are built by difference manufactures... Here its built by Kenwood... Over in the states they use RF... chances of anything being compatiable is going to be low.
They also have a better voice control system on the OS MMCS..
Its not only OEM head units that we get ripped off on.. even After market units are watered down for us.
I had my eye on a pioneer head unit (prior to learning about there quality issues)... loved all the features, HDD, Voice control, etc... only to find out that the Aussie delivered version didnt have the HDD or Voice Controls and a few other features.. but it still cost the same.
So here's the Mits bulletin for the new MMCS and in car audio touch screen system:
I am not impressed.
Point to note is the new maps are now on SD card (there is NO MORE DVD drives in these cars), so you do wonder if Version 18 maps is the last one?
I am not impressed.
I also see a 'revised CVT logic' in there too. that could just be updated TCU software
Future proofing can only be done to a degree otherwise what is the motivation for you to purchase a new vehicle in 12 months time (some people do)
My Question.
How does the DVD work?
Is it only to upgrade new maps?
Or is it required in the unit in order to run.
If the DVD is purely to update the maps. I would bet that somewhere on the mainboard there would be either a serial pinout or some sort of JTAG pins.
If anyone has a unit that they are game to test. detailed high res pictures would be a plus.
you will probably have to power the unit independently (not connected to the car) + some soldering skills to test the pins.
all of the wires\connectors can be bought from jaycar\ebay.
There is also a chance that the unit is not made by Mitsubishi just assembled then flashed with MMCS firmware then installed into the vehicle.
If we can find out who makes it maybe they would be willing to provide detailed schematics?
If you can access the bootloader. the device is yours.
My Question.
- Sir Lancer-lot
Not sure if this is the right place to post this Q but...
Oddly my A04 MMCS altitude reading is only fluctuation from 0 - 50 - 90 - 0 on the hour trip to work and back - any ideas why - the trip is far more variable than that and wasn't happening before (not that I look at it at much)
No idea how it get this reading but seems to be related to the air pressure reading - clues?.
2011 VRX Sportback - 2.4L - CVT - MMCS
I cannot confirm this but it seems to be common with most "consumer grade" software.
Most altimeter displays in vehicle only can update in either 0-25-50 feet increments.
The other factor would be how often it polls the sensor for an update.
If you are blasting through the hills at high speed then you may not see anything register on your altimeter until on your way down
Maybe take it a little slower and you might get some finer details?
Mutant VRX
- Lancer Learner
Hi, just posting some info, maybe someone has already reported this, but maybe not.
I have a 2008 VRX Olympic edition with MMCS Ver A01 Rockford Fosgate, I went to the local dealer and the Mits spare parts system reported no iPod cable was supported. I pulled the dash apart in the dealer driveway and the spare parts guy helped me out by opening a current version iPod cable to test.
Plugged it in and it work perfectly with an iPhone 4s.
The cable part number is MR936970. See photos (hope the link works)
Cheers,
Mutant
Cable and docs
Back of unit with iPod and reversing camera ports
391 tracks on my iPhone 4s. The iPod shows up where the Aux normally does when you select "Mode" in Audio
Part number on the bag from Mits Australia - all good
This cable does not charge the iPhone 4s, it needs to be moded or you can buy an adaptor from Mits for $40. I will cut the cable open and add the resistor network later (info on iPhone charging circuits is on the Web)
Cheers,
Mutant
Cable and docs
Olympic VRX
