Michael, if you are after the Ford oil best to buy from ford dealership spares part department.
or you can buy them from AK Racing.
SST Fluid comparison - Results
fisheye2 wrote:Thamks for the quick responses. Thought Id paste the response I got from Fuchs who also stock fluids for our cars. HI Michael I can help with supply ATF DCTF available in 5 X 4litre $225.00 including Supergear LS 80 90  4 X 5 litre  $270.00 including This is the way it’s sold as this is wholesale Delivery is included in Metro Best regard s Jeremy I should add that I also rang Bursons who quoted me $84 for 4L of the sst fluid Cheers
Use at your own risk
sst fluid
Keep us in the loop about the transmax dual the onky stuff I no that is close up diaqueen isthe ford fluid or the transmax dual I hope they have not led you up the garden path let
sst fluid
fisheye2 wrote:The fuchs stuff is damn cheap...you up for testing that? Ive got some left. Used it for 12000kms so far and I dont baby her around...
Hey mate - PM me and I'll send you my address. I can run a quick FTIR test to look at chemical composition and see pretty quick how similar it is.
sst fliud
Buy the ford stuff it is the same. Buy it for about $34 bottle You will need 8 bottles Gary
No luck with testing the Fuchs fluid sorry guys - it seems we had a power surge here that looks like its fried the FTIR
Won't be able to do anymore testing now, as the machine was quiet old and getting it fixed will be next to impossible...
