Performing oil change, quantity and location of sump plug?
aznlancer08
Postby aznlancer08 » Sun Jan 17, 2010 1:28 pm
Car approaching the 40,000km mark, i do a change every 5000-7500km's. two questions:
1. where abouts is the oil drain sump plug?
2. how much engine oil does a CJ need?
any help appreciated!
If you see a blue lancer in Melbourne and it looks like a VRX, that'll be me!
Mizta B
Postby Mizta B » Sun Jan 17, 2010 1:37 pm
Gday Tony
After you jack up your car and place stands under it,there is a splash tray you need to remove (4 bolts),then you will see a hex headed bolt (approx 17mm) towards the front of the engine on the sump
When you replace this plug you will need a new washer for the plug as well as 5 Litres of oil of your choice and a new filter
Pretty easy to do mate
Good luck - Chris.
Merlinised....
aznlancer08
Postby aznlancer08 » Sun Jan 17, 2010 1:46 pm
Mitza, thanks for your helpful reply.
With the new washer is this a specific part that has to be purchased from Mitsubishi?
Sickbunny
Postby Sickbunny » Sun Jan 17, 2010 1:51 pm
Yeah you can buy the sump plug washer from Mitsubishi.
I normally replace the sump plug also as its only a few dollars i think.
aznlancer08
Postby aznlancer08 » Sun Jan 17, 2010 1:54 pm
ahh, damn, i wonder if i can buy the washer from autobarn, or repco's as i was hoping to do the oil change this arvo....!
thanks for your help though!
Postby aspir3 » Sun Jan 17, 2010 2:20 pm
The washers can be bought at any automotive shop.
They are just a cheap copper washer that squashes between the sump and the head of the bolt. They can be reused and normally do not leak afterwards.
It is safer to replace. They often come in those little packs with 3 washers in the pack. They are on the rotating stand with bolts, nuts, plastic clips etc.
Sickbunny
Postby Sickbunny » Sun Jan 17, 2010 2:21 pm
you probably can, i think i remember seeing autobarn or supercheap have a sump plug and washer in a little packet on the racks where they have bolts and car clips.
SIR-VRX
Postby SIR-VRX » Sun Jan 17, 2010 2:24 pm
Recpo should have the washer...
And the oil required is not 5L MiztaB!!! (unless you were talking the bottle size)
The engine oil fill is only 4.3L. It is written on page 9-14 of your car handbook.
Mizta B
Postby Mizta B » Sun Jan 17, 2010 3:55 pm
Yes mate I know but you need a 5 Litre for the extra .3 otherwise 4 Litres would suffice = Obvious I would have thought!! :wink:
Merlinised....
SIR-VRX
Postby SIR-VRX » Sun Jan 17, 2010 3:56 pm
I just thought it would need to be clarified based on the original question.
Mizta B
Postby Mizta B » Sun Jan 17, 2010 3:58 pm
Fair enough then I should have been more precise with my answer
Point taken oh wise one!! LOL :P
Merlinised....
SIR-VRX
Postby SIR-VRX » Sun Jan 17, 2010 4:01 pm
Had he asked 'how much oil do I buy?" it would be different :P
Return to “Maintenance”
