Word of caution (zorst, not RTA or LAW related)
spunkybob
Postby spunkybob » Wed Jan 13, 2010 11:12 am
Hi All,
I while back (very long while) I posted about a squeaking noise coming from the front underneath my car.
Well it turns out its not a squeaky fan belt (as lost of people said) and it was directly related to removing the rear muffler and putting in a replacement (my case a cannon, its off now)
The issue is this. See image then explanation
Now the red circles are the factory zorst mounts, there just rubber.
By removing the lower left mount as it was not needed to hold a replacement muffler in place, there is nothing to hold up the piece where it attaches to the main zorst (blue circle) and as such puts allot of strain on the mount near the CAT.
What was happening is that the middle mount was unable to hold up the weight of the middle part of the zorst (blue circle) properly and was stretching, nearly to the point of breaking.
I had a look under there and was like WTF!!!! it was literally sagging 5CM lower then it should have been. (maybe 6 months of new muffler fitted)
If you have replaced the muffler and no longer using the rear left mount, and they have not made another 1 near the joint, get it checked out, because I can assure you the same thing will happen.
>CLICK HERE to view My 08 Lancer in all its Glory!
"Its STILL happy go fun fun time!"
scraverX
Postby scraverX » Wed Jan 13, 2010 12:12 pm
Useful info there Spunkybob. I've noticed the Greddy SE uses three mounts as opposed to 2
+1
Car & Home audio nut.
Postby ofey » Wed Jan 13, 2010 12:16 pm
Great info Bob!
exaltd
Postby exaltd » Wed Jan 13, 2010 3:42 pm
So the GReddy shouldn't sag right? :)
Great info, btw :)
Graham
Postby Graham » Wed Jan 13, 2010 3:52 pm
Great info, this should help other users avoid this problem :)
How hard would it be to make a custom mount?
Zip ties + piece of metal + welder? :P
Daily Driver: Yamaha R1
spunkybob
Postby spunkybob » Wed Jan 13, 2010 4:01 pm
show me a pic of the greedy zorst and I should be able to tell you.
Id hope there good enough to realize this problem though.
tryg
Postby tryg » Wed Jan 13, 2010 5:10 pm
It is the exact reason I designed mine to sit laterally, and have the huge bend most people thought was not great.... due to the exact reasons you stated. It is vital to even out or distribute the hanging weight.
+1
vi93r
Postby vi93r » Wed Jan 13, 2010 5:22 pm
GReddy SE is fine, you can see where it attaches in the image below on the far left. Its been designed that specifically to the lancer as it lines up perfectly to a pre-existing hole in the rear suspension.
R4LLI4RT
Postby R4LLI4RT » Wed Jan 13, 2010 5:52 pm
useful information
thanks for the heads up
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
spunkybob
Postby spunkybob » Wed Jan 13, 2010 5:54 pm
vi93r wrote:GReddy SE is fine, you can see where it attaches in the image below on the far left. Its been designed that specifically to the lancer as it lines up perfectly to a pre-existing hole in the rear suspension.
Yeah that's perfect, +1 Greedy :)
tryg
Postby tryg » Wed Jan 13, 2010 6:17 pm
Pity they have yet to make a twin system for the base models..... Now that would be perfect!
spunkybob
Postby spunkybob » Wed Jan 13, 2010 6:43 pm
I think someone in US has.... but you need read diffuser for it to work.
s84kam
Postby s84kam » Sun Jan 17, 2010 2:08 pm
holy crap i think i have this issue, do you think this would have caused any other problems due to wear?
driftnut((
Postby driftnut(( » Sun Jan 17, 2010 9:32 pm
im gonna check mine right now thx bob
