OOOOO NO
Peanut
OOOOO NO
Postby Peanut » Tue Dec 08, 2009 9:23 pm
Well had a very big problem and its freaked me out fiercly, driving home tonight it started raining cats and dogs, so just drove along, then went to catch up to mate as soon as it went over 4 grand (when mivec starts) it just pinged its freaking head off, did it through 1st 2nd and 3rd gear, stopped let it idle for a bit and was fine for a little then started doing it again, then stopped so i geared down to second and the traction control service light came on, turned the car off and restarted it and it seems to be fine now, any suggestions.
My personal opinion is that the CAI got a mouthful of water and the water was just screwing sh!t up, ill scan it when i get to work tomorrow and see what it says.
Look Out! in The Shire!!
The Can Crusher, Tuckin' Rubber, Pancake Flat. - CCJ Premium Member #0022
bobcrusader wrote:
Blake, you must be a member of the fun police? Do you know my wife?
spareparts
Postby spareparts » Tue Dec 08, 2009 9:29 pm
hey y u askin us your the mechanic... lol but u proberly rite tho
the voices may not be real, but they have some pretty good ideas :D:D
Peanut
Postby Peanut » Tue Dec 08, 2009 9:33 pm
spareparts wrote:hey y u askin us your the mechanic... lol but u proberly rite tho
I know that lol just want imput and to see if its happened to others
spareparts
Postby spareparts » Tue Dec 08, 2009 9:35 pm
lol i havnt had that issue at all.... altho mine did pop an abs code while on the dyno
tadz0rz
Postby tadz0rz » Tue Dec 08, 2009 10:09 pm
You got the hydrosheild on the CAI filter?
I always thought our cars were too piss weak to suck up water..Did you drive through puddle when it pinged?
SIR-VRX
Postby SIR-VRX » Tue Dec 08, 2009 10:17 pm
FYI Peanut, our Mivec is not staged... It's constantly variable so there is no "kick in" point as such ;)
As for the problem, plug your scanner in and see what it syas, but sounds like it could've been water
Blakey
Postby Blakey » Tue Dec 08, 2009 10:57 pm
wouldn't water create large amounts of steam causing large amounts of pressure in the piston, damaging the block or piston or bearings?
scraverX
Postby scraverX » Wed Dec 09, 2009 12:04 am
I choose to blame the cows. That or aliens. I'm not too sure.
Car & Home audio nut.
Peanut
Postby Peanut » Wed Dec 09, 2009 6:14 am
Yeah tadz i have the shield, no puddle but heaps of rain.
Thanks for the info SIR VRX, thats what i am thinking,
Blakey i know it hasnt done any damage cause the car was pinging not missing, so there isnt any damage to the motor
billyboy
Postby billyboy » Wed Dec 09, 2009 12:10 pm
So did your check engine light come on as well?
I've had water get in through mu CAI on my old mazda 3, not pretty at all! went crazy choking up & smoking fiercly out of the exhuast & CEL came on until I dried it out & disconnected the batt.
Maybe pull out the MAF sensor to see if its wet inside the pipe.
Its a worry :(
Peanut
Postby Peanut » Wed Dec 09, 2009 5:09 pm
OK well everyone stop panicing lol i scanned the car at work today, it didnt leave any Hard DTC on the ecu so it wasnt bad so i guesse you can chalk this one up to water getting in the CAI and a great limp mode and protection by Mitsubishi in the ECU, i even chuck our bore scope down each pot and nothing so, i am happy as a pig in mud and so on
LZY_EYE
Postby LZY_EYE » Wed Dec 09, 2009 5:12 pm
Good to hear peanut, you can continue crushing cans to your hearts content :P
Mizta B
Postby Mizta B » Wed Dec 09, 2009 6:28 pm
(In best Mr Burns voice) - EXCELLENT!
Mr Peanut,my arch nemesis from Wakefield lives to race another day!!!!
Muwahahahahaha :twisted:
Merlinised....
squala
Postby squala » Wed Dec 09, 2009 9:22 pm
Did it have the bypass valve? This is the solution to CAI not sucking water. It's like using two straws to sip, one on the drink and one outside.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Peanut
Postby Peanut » Thu Dec 10, 2009 6:15 pm
squala wrote:Did it have the bypass valve? This is the solution to CAI not sucking water. It's like using two straws to sip, one on the drink and one outside.
No it doesnt, the only pipe running off it is for the PVC pipe
Return to “ClubCJ Talk”
Users browsing this forum: Majestic-12 [Bot] and 21 guests
