	Power
				Midget Wrestler
Power
How do i get more power out of my new VRX??  With out spending too much money!!!!!!!
									Giddy up with the midgets
						- scraverX
Take a gander through the NA Performance thread. There are a number of options.
Also look up the site for RPW, one of our sponsors. They're located in Perth and are currently doing R&D on CJ lancer performance mods.
A lot of people choose to swap out the factory filter for a high performance one such as HKS or K&N (I have a K&N on mine), then as a further step replace the intake snorkel with the one from the Ralliart and cut out the plastic in front of the intake where the slots are. This gets more air in.
Car & Home audio nut.
- blanka
Re: Power
Midget Wrestler wrote:How do i get more power out of my new VRX?? With out spending too much money!!!!!!!
if u have the 2.4L vrx then it will be pretty powerful already, do ur bolt on mods first like intake, exhaust, pully then get a reflash and u will definitely get more power
also seen that ur in perth you should take ur car to RPW if u want more power, they can probably do u a full exhaust, intake n reflash n dyno and all that, >.< i would if i was in perth but im on the other side of the country lolz.
Uchiha Itachi
Re: Power
i can tell you alot of things you can do lol. bolt on things would be intake and exhaust(full exhaust not axle back(been told that actually gives no gains))
other things you can do is larger cam rods springs and cam seats
umm larger intake manifold( its the part after your throttle body) larger throttle body. i have been told for both of these parts you can use evo 10 ones, from JUN AUTO you can get bored out parts of both of these.
other things you can do that dont really give any power gains, you can get a larger/ lighter radiator from mishimoto.
exhaust manifold from RPW i believe it is. there is also heaps of other things that you can. to get more power. if you really wanted, buy a turbo that would be the way to get the most power.
- blanka
Re: Power
Blakey wrote:i can tell you alot of things you can do lol. bolt on things would be intake and exhaust(full exhaust not axle back(been told that actually gives no gains))
he said without spending too much money lolz
Uchiha Itachi
