Random Tips thread
spunkybob
Postby spunkybob » Thu Jan 15, 2009 8:40 am
CatP wrote:
spunkybob wrote:me either... according to pheonix the best to use is 95 as it gets the most K's for cost
Actually, you will get more km from a higher octane fuel in most cases.
This is true.... but value for money is apparently 95.
TIP FOR THE DAY:
Don't use MSN at work when the boss is standing behind you.
Tarquin
Postby Tarquin » Sat Jan 17, 2009 12:07 pm
HOGGY wrote:You are 20% less likely to have an accident if you have your lights on full time, day and night.
I agree completely.... i used to have a Gold coloured VX and I was always not being seen by other drivers.... so I started driving with lights on as often as I could - especially at dusk....
To add to the Fuel tips too - I have found the E-10 to burn too fast for the 3 cents you save, so I try to keep to use 95 or 98 RON and use a shopping docket to get the 4 cents to balance the added cost from normal ULP
- CCJ Premium Member #0015.
Tarq's Paintshop
Mizta B
Postby Mizta B » Sat Jan 17, 2009 1:56 pm
Lights on - Great idea for high visibility.
I use 95 RON all the time and get good economy,I've gotten down to 6.1 Litres/100KMS on a trip using the cruise control a fair bit to avoid Highway patrol surprises!
98 RON is good occasionally on a trip to clean out the cobwebs and the injectors.
Cheers - Chris (mizta_b).
Merlinised....
