Turbo
blanka
Postby blanka » Fri Oct 16, 2009 7:06 pm
so is it just the turbo or the whole kit
Uchiha Itachi
Speedie
Postby Speedie » Fri Oct 16, 2009 7:10 pm
I've got the turbo, zurst manifold, downpipe, airbox, inlet pipe and upper and lower IC pipes.
blanka
Postby blanka » Fri Oct 16, 2009 7:13 pm
nice if u still have the parts in 12 months time ill message u lolz
Uchiha Itachi
SIR-VRX
Postby SIR-VRX » Fri Oct 16, 2009 7:16 pm
You will need more than what he has to turbo your rehular CJ, but it is a step in the right direction, and a decent sized one.
blanka
Postby blanka » Fri Oct 16, 2009 7:20 pm
yeh still 50/50 on turbo waiting til the end of next year when i get off my p's then ill make a descision
Uchiha Itachi
Speedie
Postby Speedie » Fri Oct 16, 2009 7:27 pm
I've still got more upgrades in the post so as they come along the list will get bigger
LZY_EYE
Postby LZY_EYE » Fri Oct 16, 2009 8:17 pm
Verrrrry tempting. Worst thing is that my car is a daily drive so couldn't pull it off the road long enough to develop it.
Blakey
Postby Blakey » Fri Oct 16, 2009 8:42 pm
your gonna need more then just the turbo kit. im pretty sure the stock turbo runs pretty high psi. at least over 10. you will need at least to get new cams cam springs and cam seats or what ever they are called. need stronger intake manifold possibly higher compression pistons umm what else better bearings basically completely new engine internals. or you risk the possibility of blowing your engine. ORR you can run the turbo at a much lower psi. up until you get new internals.
but i must say the RA turbo is probably your safest option for a turbo with out major problems but you will still need a major ECU reflash or at least have the RA ECU ROM put on your ECU
LZY_EYE
Postby LZY_EYE » Fri Oct 16, 2009 8:48 pm
I understand all the extra items that would be required. I would not be running high boost into the engine.
As for the ECU flash, that is on the agenda regardless of turbo :D
Blakey
Postby Blakey » Fri Oct 16, 2009 8:50 pm
yer but if you do you will require another one after the turbo is installed or right after you get it installed. otherwise your car will run horridly with the stock es ROM
LZY_EYE
Postby LZY_EYE » Fri Oct 16, 2009 9:21 pm
I am aware of this,
I have serviced for my mate who is ex NSW state rally champion, has been in the top 5 in an asia pacific event, and in the ARC. I have plenty of people and information if I were to do it.
The big issue is I cannot pull my car off the road for weeks to do it, and am strongly considering saving up for an evo :D
SIR-VRX
Postby SIR-VRX » Fri Oct 16, 2009 9:22 pm
Oh burn
Skitzo4Bass
Postby Skitzo4Bass » Sat Oct 17, 2009 12:35 am
Do it lzy_eye... get an evo but yes there's lots of work to be done with putting a turbo in but is rewarding when you have the time and money to do so.. it would be much easier to just buy a car that comes with a turbo already but some people just don't have money (especially myself) to buy and evo or to add a turbo to the existing car..
All i can say is best of luck to you Speedie, i'll be watching out for your progress and admiring your ride
Users browsing this forum: No registered users and 46 guests
