4b11 plus turbo problems
CJ Lancer Turbo Performance Modifications & Information.
Kvalderama
Postby Kvalderama » Mon Aug 08, 2022 4:36 am
Hi iam just finished adding a turbo on a '17 lancer gta and having some problems.
Rough idling even if i drove it for an hour to relearn the ecu, also it has a cel codes p0068 (maf, map, tps correlation) and p061a (torque monitoring). The ecu is not flashed yet. Anyone with experience could chime in. Thanks
adamhumphrey
Re: 4b11 plus turbo problems
Postby adamhumphrey » Mon Aug 08, 2022 8:44 am
It sounds like the car is throwing codes due to the increased airflow for the map, maf and tps. Its most likely due to being outside the values the ecu has predefined. The two codes are related. I would get the ecu tuned and that should sort the issues.
Torque Monitoring explaination and info
http://mmc-autoelectric.org.ua/manuals/eur/lancer_sportback/2012/13/html/M113178780008700ENG.HTM
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
awood
Postby awood » Mon Aug 08, 2022 9:57 am
And more images of the build process please.
Kvalderama
Postby Kvalderama » Mon Aug 08, 2022 11:42 am
Its a custom built turbo pipings
Vf38 ball bearing turbo
Arc bov
Intercooler
Oilcooleer
Etc
Still stock on injectors and fuel pump but i have a fic injectors and a large pump.
On first start after the bukld it is ok and drove it like 30 mins but on the second till now it is running like crap specially on idle.
Kvalderama
Postby Kvalderama » Mon Aug 08, 2022 11:59 am
Here is the pic of the ecu
Can this be reflashed?
Postby lancerdarryl » Mon Aug 08, 2022 12:39 pm
Left hand drive car?
lancer2014
Postby lancer2014 » Mon Aug 08, 2022 12:46 pm
you have to reflash
evo x turbo kit
RRM crank pulley
Magnaflow cat back 2.5
Tein Flex Z Coilovers
Avid 1- 06 18 x 8.5 x 35et
Kvalderama
Postby Kvalderama » Mon Aug 08, 2022 3:58 pm
Yes this is a left hand drive
Yup i have to study how to reflash, i am used to standalone systems where open loop tuning is straight forward
Do i have to replace map sensor? I am not planning to boost above 1 bar.. could a stock map sensor handle below 14 psi?
adamhumphrey
Postby adamhumphrey » Tue Aug 09, 2022 1:10 am
The stock evo x map sensor reads to 3 bar I think
