New/Old Member - North Brisbane
SDennis_Evolution_X
Postby SDennis_Evolution_X » Sun Jan 12, 2020 11:06 pm
Hi all!! New to the forum (again after being inactive)
I own a 2008 Evo X, I've owned this car for over 7 yrs now, its gone through a few light changes over the years. Trying to keep it low key and minimal in a way.
Here are a couple of photos, its currently waiting on a heart transplant which I might update on in a different thread. Who else is around Brisbane?
I've done a lot of work over the years so any questions I'm more then happy to help out where I can.
It’s as much about the journey as it is the destination!
“Built” Blood Red Candy Evo X
Owner of Evolution X Design
Insta - scottdennis86
Build thread viewtopic.php?f=5&t=25484
Re: New/Old Member - North Brisbane
Postby bumblebee » Mon Jan 13, 2020 5:43 am
G'day
There's a few of us from Brisbane and surrounding areas.
You mentioned the car is getting a heart transplant.
What's wrong with the motor that it needs replacing?
SDennis_Evolution_X
Postby SDennis_Evolution_X » Mon Jan 13, 2020 5:48 am
bumblebee wrote:G'day
Hey Bumblebee!
Rod 2 decided it wanted to escape back in October, mind you its had a pretty good run with 218,000kms and 320+awkw so im not overly surprised or annoyed. Everything almost fell into place as i was building a motor for it anyway.
Postby bumblebee » Mon Jan 13, 2020 5:51 am
Mmm
Bugger
That's no good.
Run E85 in it?
SDennis_Evolution_X
Postby SDennis_Evolution_X » Mon Jan 13, 2020 5:54 am
bumblebee wrote:Mmm
Bugger
That's no good.
Run E85 in it?
Yeah mate, it has/had a full flex tune. nothing wrong with the tune, it had been pushing the limits for a fair while. Was on 98 at the time. Im not even worried about how or why it happened. I know it wasn't tune related. It was just its time to say good bye.
Postby bumblebee » Mon Jan 13, 2020 5:56 am
Fair enough
mr_evo
Postby mr_evo » Mon Jan 13, 2020 6:58 am
That colour mmm :)
:D I'm back baby! :D
Enkei - HKS - Turbosmart - Cosworth- TMW - Defi - DeatschWerks
SDennis_Evolution_X
Postby SDennis_Evolution_X » Fri Jan 22, 2021 3:58 pm
UPDATE! (Belated)
New engine/turbo set up is in!
As it sits now is as follows
Head
GCS Manganese valve guides
GCS Valve stem seals
Super Tech Inconel Exhaust valves
Super Tech Black Nitrate Intake valves
Ferrea Titanium retainers
Kelford valve springs
AMS TMP Cams
AMS Billet Cam Cap
ARP 2000 cam studs
Driven Fabrication Billet Exhaust MIVEC housing
Ported intake and exhaust
Flow tested
Block
Nitto 2.2lt stroker 88mm 9.2:1 pistons
ARP CA625 rod bolts
Darton MID sleeves
ARP CA625 Head studs
ARP 2000 main studs
MAP Billet timing guide
Custom Oil cooler
Raceworks braided oil lines
Cosmetic 88mm head gasket
Torque solutions front engine mount
Torque solutions rear mount
Engine bay accessories
Carbon bonnet struts
Carbon fuse box covers
EXD firewall heat shield
EXD mivec sensor heat shield
EXD cam and turbo outlet heat shield
EXD tubular manifold heat deflector
EXD coil cover
Weapon R coolant tank
Weapon R power steering reservoir
EXD 3 piece Aluminium undertray
EXD oil cooler
Mishimoto Radiator
Mishimoto Thermostat
Mishimoto Thermo Fans
Turbo/Exhaust
Custom CRG high mount manifold
BW EFR 7670 T4
Twin Turbosmart 40mm waste gates
Custom CRG 3.5” dump pipe
Custom CRG 3.5” Cat back
Intake/Intercooler
Custom 3.5” intake with heat shield
6” K&N dry pod filter
Upper and lower hard piping
Race works 2.5” pipe coupler
TS compact BOV
PWR intercooler
Driven Fab air/oil separator 10an
Race works braided lines and fittings
Fuel
Oem lift pump
Raceworks surge tank
Walbro 460
Easy controller fuel controller
Walbro 255 hard wired
Twin 6an raceworks braided feed lines
Works fuel rail
ID1700 injectors
TS 1200 FPR
Blue Flex flex sensor
Body
Custom blood red candy respray with gloss black roof
Ralliart carbon lip
Rex speed carbon nose piece
Carbon bonnet vents
Varis carbon pillar panels
Carbon side skirt extensions
Varis style carbon diffuser
Carbon exhaust shrouds
Black Hawk Limitless 2.0
Head lights
Retrofitted Depo projectors
Evo-XR bixenon projectors
Demon eyes
Switch back 3/4 halos
RGB half moon halos
Suspension/Wheels/brakes
MCA Reds coil overs 11kg/12kg
Work D11r 18x10.5+22 matte bronze discs matte black barrels
Work emotion flat black/chrome center caps
MCA real nuts
OEM Ralliart front strut brace
OEM Ralliart rear strut brace
DBA t3 front rotors
DBA t2 rear rotors
Carbon front air guides
HEL braided brake lines
Drive train
MAP E9 CMC upgrade with braided clutch line
DCS twin plate ceramic
ACT monoloc
Radium Engineering Clutch fork stopper
Torque solutions shifter bushings
Torque solutions shifter base mounts
COBB short shifter
White line rear diff bushes
Interior
Redline leather steering wheel retrim
Redline leather gear boot
Redline leather console retrim
Android head unit
AEM wide band
AEM boost gauge
AEM oil pressure gauge
EXD fire extinguisher bracket
Ortiz twin dash pod
Custom ash tray gauge pod
Alpine Halo9 head unit
Last edited by SDennis_Evolution_X on Sat Jan 23, 2021 10:19 am, edited 1 time in total.
awood
Postby awood » Fri Jan 22, 2021 7:33 pm
Nice work.
CJVR08
Postby CJVR08 » Fri Jan 22, 2021 7:48 pm
WOULD be nice to have that kind of money to spend
Postby bumblebee » Sat Jan 23, 2021 7:05 am
Very nice
I bet the 2.2 stroker goes like a rocket ship
There is also from memory a 2.5L stroker for the Evo. Either way , will definitely give it a decent kick up the backside power wise for sure.
Taken it for a run down Willowbank ?
What kind of times are you running?
SDennis_Evolution_X
Postby SDennis_Evolution_X » Sat Jan 23, 2021 10:06 am
CJVR08 wrote:WOULD be nice to have that kind of money to spend
There has been a lot of saving and preparation for this build, it doesn’t just happen.
SDennis_Evolution_X
Postby SDennis_Evolution_X » Sat Jan 23, 2021 10:11 am
bumblebee wrote:Very nice
Technically with the over bore as will it now has a capacity of 2.3lt. I wouldn’t go any further over bore then 88mm though as there has been reports of lots of head gaskets leaking due to not enough sealing area etc. the build was only completed in early 2020, final tune done in September 2020. Due to the fact I work away this last year has been much harder with border closures and not being able to get home to work on the car or put kms on the engine for run in. So again due to time constraints I haven’t run it at willow bank, though I’m more interested in sprint racing then drag racing. Hopefully will be out in the street sprints series this year.
SDennis_Evolution_X
Postby SDennis_Evolution_X » Sat Jan 23, 2021 10:13 am
awood wrote:Nice work.
Thanks mate! It’s been a long time coming! Finally getting to a point when I can say it’s finished
Postby bumblebee » Sat Jan 23, 2021 5:07 pm
Goto a test and tune night at Willow bank and get a time slip
From memory $20 thru the gate
$50 to run down the track all night long
Best way to see if all you time , effort and $$ work is to shove it down quarter
The timing gear will give you the best indicator of it all working or not working regardless of how many dyno charts you may have
