Front fender removal
Tywhiteguy
Postby Tywhiteguy » Tue Nov 26, 2019 10:15 am
Has anyone removed their front fender? I got all the bolts off except the one in the door jam. I tried using an impact with a long extension, a regular socket with an extension but it seems if I open it too far the door gets in a the way! Any tips would be greatly appreciated
FYI it’s a MY12, not sure if that makes a difference but the one photo explenation I found has a different arrangement
2012 ES Sportback USDM Long Beach, CA. RA Snorkel, K&N Drop-In,Custom 2.25 catback with Flowmaster resonator+jdm 4” muffler, Gutted from rear seats back, Pioneer AVH-211EX+12” compact sub :welcome:
Re: Front fender removal
Postby bumblebee » Tue Nov 26, 2019 5:13 pm
It may be easier to remove the door
If you follow the rubber tube that runs between the door and the pillar , inside there is a clip plug
The clip plug will.pull apart
Once the plug is apart that's it for the wiring to the door
Remove the bolts and the door falls off
Users browsing this forum: Majestic-12 [Bot] and 14 guests
