Hi all, so I have a lancer di-d, it's basically lancer with a Vw diesel engine in it.
I'm looking to upgrade my front brakes, I'd like Togo for bigger so I purchased outlander claipers but they won't fit the hubs.
Does anyone know of any direct bolt on calipers that fit a stock lancer?
Thanks from England
Brake upgrade lancer saloon gs4
Re: Brake upgrade lancer saloon gs4
Diesel Saloon...
Might need to tell us the specs your Lancer has as nothing like that was sold in Australia where this forum is based.
That said I'll take a stab and the EVO brakes will probably bolt on with the right wheels, but I'd wait for someone better informed then myself chimes in on the topic.
We don't get the diesel lancer or the AWD NA models in Australia so we cant say for sure if it will be be a direct bolt on but...
A few members have upgraded their stock (single piston caliper) to the Ralliart twin piston caliper but only on the front wheels.
For us they are direct bolt on upgrade.
K+N drop in
RA intake
SS 4-2-1 Headers
Whiteline Strut Brace
Whiteline Rear Sway Bar
Paddle Shifters
Merlinised
RA intake
SS 4-2-1 Headers
Paddle Shifters
Merlinised
You need to find a VRX/GTS with a 2.4 (4B12) engine and use the front hubs and rotors and a pair of calipers from a Ralliart.Evo brakes will not fit.
Bolt on is such a loose term, just about anything will bolt on depending what other parts you replace.
As I asked knowing the spec of the current brakes is a good start to know what might fit.
Why didn't we every get a diesel CJ or a NA AWD?
Over here in Australia the ralliart and Outlander 2.4 have the same brakes. They are twin piston with 130mm bolt gap. That is the secret. To find calipers with 130mm bolt gap. I'm sure there would be other Mitsubishi models the same that fit. Eg I know the Evo 1-3 and some Magnas are the same too. I've never checked newer models like ASX.
