Hiya!
saw these, they look pretty good, wanted to know if anyone had installed them, how difficult it was and how they work with the Halo and fog light capabilities (switches and such)
https://www.aliexpress.com/item/1pair-A ... 9f3d622a-1
cheers
Halo Fog lights
- Ronan.Butler11
Halo Fog lights
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re: Halo Fog lights
Would like to find replacement fog light surrounds with just daytime driving lights (strip) for MY15
- MiracleLancer
Re: Halo Fog lights
I wonder if you can get a variant of these for the CF.
Then again I'd have so many running lights if I did that lol xD
Tenzo-R Cuzco V.1
Tenzo-R Cuzco V.1
- Ronan.Butler11
Re: Halo Fog lights
sarusa wrote:Would like to find replacement fog light surrounds with just daytime driving lights (strip) for MY15
i know these are definitely a thing. from memory (will try to find them again) they were made for those who didnt have factory Fog lights, lemme try and find them again, will post link if i do
***EDIT*** Got em
https://www.ebay.com.au/i/192293392026? ... dispItem=1
these what you mean?
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
- Ronan.Butler11
Re: Halo Fog lights
MiracleLancer wrote:I wonder if you can get a variant of these for the CF.
https://www.ebay.com.au/itm/MITSUBISHI- ... 2623290743
looks like you might have 2 more drl's runnings hahaha
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re: Halo Fog lights
I have installed stocko fog lights to the r.a front end on the active
Piece of cake
The fun bit is running the wiring into the cabin.
Piece of cake
- MiracleLancer
Re: Halo Fog lights
Well, Looks like I'll be adding these to my list of stuff
Tenzo-R Cuzco V.1
Tenzo-R Cuzco V.1
Re: Halo Fog lights
Pretty simple
Remove the black plastic surround from the bumper
Fit the lamps and wiring to bumper
Reattach the light surrounds
Run the wiring into cabin
Remove the plastic cover above driver knee
Mount switch and attach to wiring loom supplied
I used the trigger wire from the positive side of the parker lights to switch the relay on for the fog lights
So for fog lights to come on. Parkers must be on
Then connect positive lead from wiring loom to battery.
Connect negative feom wiring loom to chassis near battery. There will be one near the battery already.
Then you can stsrt car.
Flick parkers on
Press the foglights switch above your knee you mounted
And all being equeal the foglights come on
Job done
Im more then happy to fly to you and install them
You pay the flights and travel to you and its done.
Lol
Flick parkers on
Job done
Lol
Re: Halo Fog lights
Ronan.Butler11 wrote:Hiya!
https://www.aliexpress.com/item/1pair-A ... cer-2008-2
cheers
Unfortunately these are for pre 2013 lancers.
Looks like I'll have to settle for round lights in the space currently housing dummy fog lights.
- Ronan.Butler11
Re: Halo Fog lights
bumblebee wrote:Pretty simple
Flick parkers on
Job done
Lol
So would it be for main fog light i still use the current fog light switch on the indicator lever, then the switch near the driver knee area for the halo?
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re: Halo Fog lights
My lancer doesnt have a fog light switch on the indicator stalk
Thats why i used the positive off the parker light as a trigger on the relay so when the parkers go on then i can use the fog lights
If you have a lancer activ (they have the r.a bumper) you will need this ebay part number for fog lights
391448469259
391448469259
