2010 Ralliart
W45H
2010 Ralliart
Postby W45H » Fri Apr 22, 2016 7:50 am
Hey Guys,
I'm thinking about buying a 2010 ralliart with 104000km. Its due for a service as the last one was at 90000km. Is there anything major i should look for when inspecting it? I'm taking it to my mechanic on the weekend to have a look
merlin
Postby merlin » Fri Apr 22, 2016 8:29 am
Look for oil leaks and any evidence the transmission is not behaving correctly.
Best to get a Ralliart owner to also drive the car to check for tranny weirdness.
efod3
Postby efod3 » Fri Apr 22, 2016 12:21 pm
Check if the SST fluid has been changed, that's done at 105k according to the schedule but should be done much more often than that. It isn't cheap so factor in up to $1k for that if it hasn't been done.
Also the timing belt is, according to the service schedule, meant to be done at 100k. Chances are it hasn't so factor in that as well at some point in the not too distant future, again, pricey, over $k prob.
I think they're the two main costly items you want to check from the service history.
burfadel
Postby burfadel » Fri Apr 22, 2016 4:24 pm
efod3 wrote:Also the timing belt is, according to the service schedule, meant to be done at 100k..
Does the Ralliart like standard Lancers use a timing chain? I guess you may be referring to the early Ralliart timing chain stretch issue, I'm guessing if encountered they replace it with the stronger, later version of it...
Shaun Patterson
Postby Shaun Patterson » Fri Apr 22, 2016 7:15 pm
burfadel wrote:[quote:3ca823a385=efod3]Also the timing belt is, according to the service schedule, meant to be done at 100k..[/quote:3ca823a385] Does the Ralliart like standard Lancers use a timing chain? I guess you may be referring to the early Ralliart timing chain stretch issue, Im guessing if encountered they replace it with the stronger, later version of it...
yeah 2010 has timing chain and 2010 has the V2 timing chain, yeah check that the sst has been well serviced no less than 3 times for a 104000km car i would recommend, i i personally do mine every 10-15km
W45H
Ralliart
Postby W45H » Sat Apr 23, 2016 8:54 pm
Thanks Guys I should have it next week and then bye bye to my sx :(
Return to “Maintenance”
