Hi,
I'm looking for a wiring diagram for my Lancer (2011 1,6L). I found this:
Is this universal for Lancer from 2008 till 2014? Since this is a 2008, will it be the same as for my 2011?
Just wondering. It would help me alot if I could locate correct wiring diagrams!
Thanks!
Wiring diagram
Wiring diagram
2011 lancer CY 1,6L Cleartec
CY1A / 4A92
CY1A / 4A92
Thank you for your response!
As additional info I just found this:
http://www.roadraceengineering.com/evox/tech/evox-ecuwiring.htm
Just took a look under my hood, and apperantly I'm lacking wiring in my harness to my engine ECU on pins 95, 107 and 108. (the ECU has the pins, the harness just lacks the wires. The 4A92 should be able to configure cruise control in the ECU, however the 4A91 is not. Luckily I know for sure I have the 4A92)
I need to figure out a way how to add wires to those pins, or get a donor engine ecu harness from somewhere ...
Any ideas?
Any ideas?
CY1A / 4A92
CY1A / 4A92
