aspir3 wrote:Just do it as suggested on the video. Take off the hose connected to the Tb.
The videos say spray it through the vacuum line, but shows it done through the throttle body
burfadel wrote:[quote:c705776b1f=toc]Nope, the vacuum line accomplishes this too (remember, the piston is pulling a vacuum when it draws in, with that can on the end of the vacuum line, shes definitely going to get to where it needs to get to, including in the combustion chamber and down in the plenum (vacuum line after throttle plate).[/quote:c705776b1f] Isnt there a few vacuum lines? Which one do you think would be best to use? I just had a very quick look, maybe the one for the brakes? Since the car will be stationary, in park, with the handbrake on I was thinking it would be the most practical. However, this would also throw a check engine light I would presume? Again, would this go off after a while of proper operation? Im probably overthinking it!
