Keyless operations service require?!? (smart key issue)
Shaun Patterson
Postby Shaun Patterson » Wed Oct 15, 2014 9:46 am
Hi guys, my lancer will only start using the emergency key. on the Instrument cluster it is displays keyless service required. anyone know what the issue is or will i indeed need Mitsu to service it.
mmjjee
Postby mmjjee » Wed Oct 15, 2014 10:39 am
Perhaps a flat battery?
Postby Metalstrix » Wed Oct 15, 2014 11:00 am
That's weird, I've never heard of that before. Go take it to your dealership :)
Shaun Patterson
Postby Shaun Patterson » Wed Oct 15, 2014 11:23 am
i thought i could have been battery, i replaced it and to no avail.. :/ car is dismantle have to wait till its done to get to the dealer
Postby Mystique » Wed Oct 15, 2014 6:35 pm
I think you will find that chances are because you have pulled your car to pieces... It may need to be re programmed.
Zaphod
Postby Zaphod » Wed Oct 15, 2014 7:16 pm
Have you swapped/modified the donk?
bg60
Postby bg60 » Wed Oct 15, 2014 9:55 pm
I've been told that the initial cause is a flat battery, but it will need to be programmed by the sounds of your problem, and the dealer will hit you for it. ;)
Postby VRX_08 » Wed Oct 15, 2014 10:01 pm
I know on earlier CJ Lancer's the instrument cluster actually says something more like batter is running low or something along those lines unless it is something more serious!
I have replaced mine once or twice but mine always says 'Battery running low' and I also own a 2008 CJ Lancer VRX!
Speedie
Postby Speedie » Wed Oct 15, 2014 11:55 pm
If the cars apart you may have unplugged one of the antennas for the keyless.
Return to “Maintenance”
