Cheers
Engine not turning over
- Shaun Patterson
hi guys i have my 08 vrx pull apart.. basically the interior is bare excepting wiring harnesses and dash, all the doors and trunk are off ect, today i tried to start her up and not... i can hear the starter motor doing its usual clicking and the fuel pump going but no turn over.. anyone have any suggestion on where i should start?
Cheers
Cheers
himynameisdaniel
- Shaun Patterson
- Shaun Patterson
Starter motor doesnt usally click unless the battery is dead and you hear the solenoid clicking ?
Can you do a video ?
What have you done before it ?
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
- Shaun Patterson
hmm, what exactly are you dismantling ?
Any change you got a OBD2 reader ?
When you turn the key, is it cranking and just not turning over ?
Id check for spark.
But definitely a video to help us see your exact issue and then we can help you
Id check for spark.
- Shaun Patterson
