Kav91 wrote:...Hey gramps!...
You get no respect 'round here, do you Steve
Kav91 wrote:Also an E85 monitor as you call it, is actually called an Ethanol Content Analyzer and is not $100-150 , you need the sensor as well as the display which can be $450+- upwards
jordan.fuchs wrote:[quote:b28da2b2f2=scott_drake][quote:e7e1abd1a0=Kav91][s[/quote:e7e1abd1a0] please just go to a corner, face the corner, stand straight, put your head down, and cry[/quote:b28da2b2f2] And try get there without locking up your dif and hitting a tree... ]
scott_drake wrote: > bahaha you still think i hit a tree....
> you dont even know what I hit
Like, I know E85 gives you better response and power when using it, but how come it has the ability to do that compared to 98RON or unleaded in general?
Does it have something to do with better combustion?
rokpapaziz wrote:Basically E85 has a higher knock/detonation resistance so therefore you can advance the ignition timing more than 98RON petrol, thats where most of the response and power is. Also because it doesnt create as much heat it helps with turbo charged cars with keeping the air charge and engine running cooler.
