Rattling Noise I think
- raidmaster212
- rokpapaziz
Any of you guys running the Super Sport flash? After I did mine I noticed it would not change into 6th gear at 60km's anymore in auto mode.
If I change it manually it sort of grinds, so I drive in 5th gear at 60km now.
I'm suspecting that's what killed the early model SST's in RA's.
Any how a fluid change at around 45,000km is what is in the service manual these days, my original gearbox was replaced at 75,000km. It was stock back then
- rokpapaziz
- rokpapaziz
If you're out of warranty it will be an exxy job if they have to pull the tranny. Try new fluid and filter first - Ford, Diaqueen or Castrol Tranmax Dual - all the same. Ford and Castrol much cheaper. If that helps, then winning. You could also do teach-in using Pass-Thru CAN. I did this after doing the s-sport flash and it reduced a similar issue I had. Never heard grinding, but my exhaust it to loud!
