Does anyone know if the Standard lancer brake boost is the same or different to the RA one ?
And if i did get the EVO X brake booster, will the Master cylinder fit on it ?
Thanks guys!
Brake booster the same on a Lancer Es and Ralliart ?
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
pretty sure it wont without the booster as well. then would still need modification. but the gains from it wouldnt be worth the cost. better off with really good rotors, pads and fluid.
Ok, so thanks to Michael. The part numbers are exactly the same between the lancer es brake booster and Master cylinder and the Ralliarts.
Kal777, The master cylinder off the evo x has a bigger piston in the master cylinder. 3mm bigger. And i think you need a bigger one if upgrading to brembos.
