rego check
shadow-vex
rego check
Postby shadow-vex » Tue Sep 17, 2013 9:57 pm
So in preparation of the new turbo laws in nsw, I thought I'd check out some RA's and when I did a rego check on them (the free one done on the RTA website) they said "year" Mitsui lancer "sportback" or "sedan" and then my car was special case and is listed as a 2011 Mitsubishi lancer sportback sedan, so I was wondering if there is way to make sure cars are RA's and not just have been an es model with an engine conversion etc. etc.
Thanks guys
Postby SIX » Tue Sep 17, 2013 10:04 pm
yeah check there VIN numbers on the side door when u open the drivers door that will tell u if its an RA or not ..... generally though you can always tell. because if you know lancers well you can tell when one is a fake it will miss the little details like the allumium bonnet which is lighter than the ES VR VRX Aspire steel bonnets , and look inside the cabin to see if the trannys sst, they are the three obvious ones to check ....
shadow-vex
Postby shadow-vex » Tue Sep 17, 2013 10:11 pm
I thought a vin check would still say "lancer" and yeah, but isn't it easy enough to get a replacement bonnet and how can you distinguish between cvt and sst?
Postby SIX » Tue Sep 17, 2013 10:16 pm
shadow-vex wrote:I thought a vin check would still say lancer and yeah, but isnt it easy enough to get a replacement bonnet and how can you distinguish between cvt and sst?
VINs are specific to models version of that lancer my10 VRX is different to a MY11 VRX
sst will look like this
CVT like this
shadow-vex
Postby shadow-vex » Tue Sep 17, 2013 10:21 pm
ahhh, thanks mark :)
so if u do the vin check that you pay for, that will say if its vrx, es, RA, coz I know the vin says what yr model it is
Postby SIX » Tue Sep 17, 2013 10:24 pm
nar just write the VIN on a piece of paper and pop on to REDBOOK and it will tell u what is it , but by law the caryard will still need to advertise it as an ES because that is what it it ......
take for expample denzza's rx lance , if he were to sell that with the turbo on it , it will still be an RX turbo it wont be a VRX or a Ralliart he still has to advertise it as an RX because thats what it was and still is
Postby SIX » Tue Sep 17, 2013 10:26 pm
Postby Metalstrix » Tue Sep 17, 2013 10:36 pm
Is it certain that p platers can drive turbos next year??
shadow-vex
Postby shadow-vex » Tue Sep 17, 2013 10:36 pm
yeh, I know tht, but u get the dodgey ppl who will try to get an extra buck
shadow-vex
Postby shadow-vex » Tue Sep 17, 2013 10:58 pm
MrCJ wrote:Do a PPSR that will tell you everything including if its encumbered or not
How much do they cost?
shadow-vex
Postby shadow-vex » Wed Sep 18, 2013 9:29 am
MrCJ wrote:i think there $23 they also show it the car has been in a previous accident and a heap of other stuff otherwise pm me the first 15 digits of the vin if you want and ill check it against my redbook at work ill even be ably to get you the redbook code
ohk, thanks, and when time comes to upgrade I shall pm u then :) :D
squala
Postby squala » Wed Sep 18, 2013 9:46 am
There's no way NA Lancers can be converted to become exactly like Ralliarts, just as Ralliarts themselves cannot be modded to mimic an Evos. I do know that it's hard to distinguish cosmetically enhanced CJs from the real deal as they can be changed to vented bonnets and dual exhausts, but internally, it's a giveaway. Like what was mentioned, the SST shifter looks a lot different from the manual and CVT of non-turbos. And if you can be bothered stooping down the rear axle, there is a driveshaft that reveals the 4WD system.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Return to “ClubCJ Talk”
Users browsing this forum: Majestic-12 [Bot] and 19 guests
